Old 08-10-2005, 02:39 PM   #1
Default Traxxas Jato problem
im having problems with my Jato. It willnt keep running, it stalls right after u start it up. and the rear tires are spinning when it runs. im not pushing the throttle or nothing, and i turn the throttle trim but it still spinning, they spin pretty fast to, ive tried adjusting the needles but still no help. thinking its something with the engine maybe? any help would be apreciated. thanks
Kwilli is offline   Reply With Quote
Old 08-10-2005, 03:50 PM   #2
Trader Rating: 28 (100%+)
Take apart the clutch and make sure it doesn't have a broken spring or bad bearing. I'm betting it's one of those. And reset your needles to stock settings and retune so you don't toast your motor when you get it fixed.
jbrow1 is offline   Reply With Quote
Old 08-10-2005, 09:47 PM   #3
could that proplem be whats making the engine stall to? thanks for the quick response
Old 08-10-2005, 09:59 PM   #4
Most likely that's exactly what's making your engine stall. If the clutch can't retract in like it's supposed to it means the tires will continually try to turn. If you lower the rpm's to much the motor will stall on it's own. Or if you stop the tires from turning with brakes or by hand you'll also stop the crankshaft in the engine from rotating also, meaning your engine stops.
Old 08-11-2005, 01:26 PM   #5
thanks alot JB for your help, i found a broken spring, one of the ends where it hooks on to is broken off. thanks again for your help
Old 08-11-2005, 03:51 PM   #6
You're welcome. Glad you found the problem.
Traxxas Slash and Traxxas Jato 3.3 SerpentCT4S R/C Items: For Sale/Trade 9 08-13-2008 02:39 PM
Jato brake problem Motoman Nitro Off-Road 2 07-14-2008 10:09 PM
Traxxas Jato 3.3 RTR platinumjason R/C Items: For Sale/Trade 5 08-03-2007 05:14 AM
Traxxas Jato mmarzuki Malaysian R/C Racers 12 06-09-2007 08:21 AM
hpi mt2 or traxxas jato rc fanatic Electric Off-Road 11 06-06-2005 10:10 AM
