Old 08-09-2005, 03:12 PM   #1
RatzoNitzo's Avatar
Default Kanai guy's! I need your help!
I have a brand new Kyosho Kanai 3 that I built over the winter.
I ran it, and it was a little swervy in loose dirt.
I now want to install torsen diffs in the front and center.
I get several part #'s and don't know what is right or wrong.
I figured on of you K3 experts could help me out with the correct part #'s for Ofna super torsen.
Thanks in advance.
RatzoNitzo is offline   Reply With Quote
Old 08-09-2005, 06:57 PM   #2
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
in most cases a torsen diff will make the car handle worse I would save your money.
try this setup I found on the starting grid it should get you in the ballpark
Front end: New Shocks with 1.4 pistons(white) 70wt Associeted oil.
Full travel
Blue springs, upper and lower "A" Block (red Kit Block)(old "a" block,
not the new front shock tower with red upper "a" to match) I use the
Plastic upper "A" works fine,with the Racers edge front tower.
22 Degree Caster Block.
Few degrees tow out.
15mm of ride hight clips in the front,One 10mm and one 5mm,(or if your
using the Racers edge shock bottoms,13mm clips because the bottoms add
2mm)
Rear end: new shocks with 1.4(white) with 40 wt Associeted oil
8mm ride hight clips(or 6mm with racers edge bottoms)
full travel
Rear 3 degree tow in,2degree(gold)Anti-squat, Rear hubs back.
All shock and camber postions stock Kit positions..
Diff oil 5000,7000,1000 front to rear standard(non lsd
diffs)
also try crimefighter tires they seem to work everywhere
cmain is offline   Reply With Quote
Old 08-09-2005, 07:57 PM   #3
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Why would Torsen's make the car handle worse? I just picked up a Hyper 7 pro kit, and it has front and center torsens. I havent finished building the car yet, but it was my belief that torsens help you get the power to the ground better.
Is this the case?
v0rtex is offline   Reply With Quote
Old 08-09-2005, 08:34 PM   #4
they work best on smooth tracks but make the car unpredictable on a bumpy track.
Old 08-11-2005, 05:24 AM   #5
i disagree. i tried torsens and they are awesome. it just pulls your car thru a corner.... i love it! i only used torsens in the front only though!
noobie is offline   Reply With Quote
Trying to find IGT or GTP guy's to run with (SOCAL) dbr9ifgt Nitro On-Road 18 08-25-2008 11:24 AM
What batteries do off road guy's prefer, EP / WC yuk17bandit Electric Off-Road 42 07-12-2007 02:23 AM
u guy's revo diff fluids? rhymster Monster Trucks 3 08-14-2006 08:27 AM
whats your guy's input on the new lipo technology rhymster Electric Off-Road 12 05-29-2006 12:44 PM
How much do you guy's spend in a year running your toy cars? PRO 2 RACER Australian Racing 38 11-12-2005 04:39 AM
