Old 08-04-2005, 09:06 PM   #1
GReddy's Avatar
Send a message via AIM to GReddy
Default what is this?
can anyone tell me what car is this? and is it worth 40$ ?
saw it on cragslist
GReddy is offline   Reply With Quote
Old 08-04-2005, 09:31 PM   #2
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
Traxxas Rustler. Similar to my Bandit
I have had 2 of those, gave one to my team mate, and have enough to build one more from parts. Those are probably one of the most bash worthy trucks avalible. They just don't quit!
There isn't a speed control, but those are easy enough to get, and the answer to your question is...Yes, I do find that worth $40. The tires may be something that you would want to replace, because they are pretty primitave, and have no inserts, but other than that, it looks ready to accept your speed control, and mabey a new motor. Definatly worth it. If you need more information, send me a PM.
Platinum_Racing is offline   Reply With Quote
Old 08-04-2005, 09:33 PM   #3
I'm sorry, I never actually went in to detail, it is a stadium truck, unlike my Bandit which is a buggy. My "Buggy" has had some extreme hop up's installed however. It isn't anything like a stock Traxxas vehicle anymore. The only difference between my Bandit and that Rustler, is that my Bandit has shorter front and rear A-arms, and camber links, shorter drive shafts, different factory tires, and a different factory body. Other than that, all parts are interchangable.
BTW: Traxxas makes the Rustler.
Edit: Also, it would probably be a good idea to replace the stock bushings that come with the truck, with some good oversized bearings. In order to install the oversized bearings, you will need RPM's oversized bearing carriers (RPM part #: 80372 Fronts, 80382 Rears). This little upgrade gets rid of a lot of play in the wheels, and performs better than stock bearing carriers, with smaller bearings. Hope this helps!
Old 08-04-2005, 10:38 PM   #4
GReddy's Avatar
yea thanks for the help but na i dont think i would get it
i just asked in case it was some old kyosho or tamiya you know
Old 08-05-2005, 06:52 PM   #5
Well at least now you have a set of useless part numbers...you know, just in case!
