Trinity Zombie 4x4 SCT Motor
#62
I have the timing at the 0 mark on the can. Running negative timing would start to generate heat again. I dont have to free spin it long at all before it heats up, and I wasnt anywhere near full throttle.
#63
Zero on the can is probably still 20° to 30° of timing, can't hurt to try it. Your temp gauge will tell you if you're going in the right direction.
If it is getting hot after a few throttle pulls on the bench then something else is probably going on.
I just mentioned not to hold full throttle for too long because I have seen a few people that didn't know any better so I thought I would throw it out there.
#65
My ESC is in the 120-130 range. I will try messing with the can timing somemore and see if I can figure something out. I really need to figure out whats going on cause I would really like to run this thing. I was running a fan on it to start with but for some reason the thing stopped working for me so I have a new one on the way.
#66
I just had to send in a message for support on mine becuase I still cant get the temps to come down. I have tried all pinions from 11t-16t and after less than two minutes of running I will be in the 165+ range. even without a load on it the motor will reach 150. I have no Idea what to do at this point. I don't have any timing added in esc or on the motor. When I put my tekin motor back in my motor temps drop right back down, so I know its not binding in my drivetrain.
Does anyone know of a phone number to call them? I cant find one anywhere on their website.
290 Springview Commerce Dr Ste 4, Debary, FL 32713
(386) 668-7771
#68
Do you know if this is a first batch motor?
#69
Im not sure how you can tell if it was a first batch motor. I have had it for about a month and got it from stormer hobbies, so I have no idea. I have checked out the bearings and they seem to be in great shape. One thing I did notice is that my rotor has four flat spots on it. I am not sure if it is normal or not because this is the first trinity motor I have had of this style and dont have anything to compare it to. But with my other that I have taken a part you could roll the rotor on a table no problem. This motor has four visible flat spots on it.
#71
I think there were problems on some early motors, mostly rotors. Should be all good on thenthenewer motors.
#72
And BTW, when the motor heats up quick, its an internal short. Bad stator, and it will smoke ESC.
#73
That must be what is wrong with mine. I couldn't ever get anyone to reply to my messages or call me so I guess I just wasted the money on this one.
#75
Tech Legend
maybe the 4000kv option they have would be better?
Funny, got into a nice "discussion" with someone on a more dedicated rc short course board over the term "545".
he is pretty adamant that anything bigger than a 540 is a 550 apparently even though the term "545" is how we call these motors that are inbetween a 540 and 550.
Then again, he likes to argue that up is down, left is right, etc.
