Old 07-29-2005, 11:22 AM   #16
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
ill b bashing in a local bowling parking lot.....i have the following esc's to choose from:
lrp f1 reversing
novak explorer 2
ill b running a futaba receiver and servo
trx1 is offline   Reply With Quote
Old 07-29-2005, 11:53 AM   #17
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
if you want speed you need a 12 turn mod motor. to maintain it, you need to get it cut about every 5-10 runs. and you need a esc that can handle it, such as a v7.1.
dado11g is offline   Reply With Quote
Old 07-29-2005, 12:11 PM   #18
ThePrfctGetaway's Avatar
Location: If I told you, I'd have to shoot you in the face.
Send a message via AIM to ThePrfctGetaway
Brushless seems like the way to go. My neighbor had an Novak SS5800 brushless system in his Yokomo and put it up against my Nitro TC3. I was blown away. Literally, beaten to smitherines. And the cool thing about brushless, NO MAINTAINENCE. I'm really thinking on going for brushless. If you get the SS4300 (The stock one, I think thats the right number) it'll run faster than a stock 27T motor, maybe even as fast as a 19T if not a tiny bit faster, and not need to be taken apart. Really considering it for me..
ThePrfctGetaway is offline   Reply With Quote
Old 07-29-2005, 01:02 PM   #19
What do you mean by cut?
coolguy5 is offline   Reply With Quote
Old 07-29-2005, 01:06 PM   #20
Cut?
Old 07-29-2005, 01:07 PM   #21
dado11g's Avatar
ok, there is a commutator and brushes in a electric motor... they rub on each other and wear each other out. you need to refreshg the surface on the commutator but getting it cut on a lathe. and you need to replace the brushes whenever you get a cut. by the looks of it it might be a good idea for you to go brushless.
Old 07-29-2005, 01:08 PM   #22
Send a message via AIM to T4driver
Originally Posted by coolguy5
Cut?
When someone cuts your comutator with a motor lathe
T4driver is offline   Reply With Quote
Old 07-29-2005, 01:30 PM   #23
Ok ive decide i dont have enough to go brushless and dont want to go modified. So whats a good motor between 15-17 turns? I was looking at the Orion 17 x 3 Orbital Pro BB Motor.
Old 07-29-2005, 01:43 PM   #24
What's the fastest turn motor you've ever used?
Old 07-29-2005, 02:07 PM   #25
A 19 turn motor
Old 07-29-2005, 02:23 PM   #26
dado11g's Avatar
if i were you i'd go with a high end 19t. seeing how you have a t3, im guessing the 19t you used was the rtr motor(now a good motor). a chemeleon 2 will blow that away. i really suggest you try one.
Old 07-29-2005, 02:25 PM   #27
ill try that
Old 07-29-2005, 02:28 PM   #28
dado11g's Avatar
was i right about that rtr motor?
Old 07-29-2005, 02:30 PM   #29
yea
But I looked at the chemeleon 2 at www.towerhobbies.com and is says its a modified motor
Old 07-29-2005, 02:31 PM   #30
Reason I asked what the fastest motor you used was, was because you should go at least 2T lower. Like go for a 17T. A little more wild, but not too far from you. Practice driving on that motor, then if you want, switch over again. I know it sounds nuts, but it's actually not..... It's a worked 19T motor. Very quick. I raced against my friends crappy 15T and I beat him like he was going in reverse. The Chameleon2 Pro, kinda pricy, but for the speed and performance you'll get from it, it'll be worth every penny. I got one, and it was FANTASTIC in my TC3. And also because my Dually's limiter was off..
