Hobbywing HELP
Old 02-08-2014, 01:22 AM
Gordy's Avatar
Default Hobbywing HELP
Hi Guy's
I have a Hobbywing 2250kv motor im transfering from MBX Tekno to the new MBX7eco,
The( Blue Covering) on the wires from the motor are frayed and i was wondering where i would find some new/better covering so i can replace before running the buggy,
The blue wire covering that runs into the Black plastic bit at the back!
Cheers Gordy
Gordy is offline
Old 02-08-2014, 04:40 AM
rcgod's Avatar
Trader Rating: 27 (100%+)
Heat shrink tubing should fix it.
rcgod is offline
Old 02-08-2014, 05:43 AM
+1 for the heat shrink but you may also consider disassembly and resoldering wire to the stator. Why are they frayed? Overheat, chemical exposure, or rough handling/ crash damage? If its from chemicals or overheat I would replace them all the way back to the stator if possible. Keep track of A B C.
kVar is offline
Old 02-08-2014, 08:53 AM
Precision1's Avatar
Trader Rating: 40 (100%+)
Don't take the wires off or shorten them!
On this motor they are part of the winding (which is why they are so stiff near the can) and need to stay the correct length to function correctly.
Precision1 is offline
Old 02-09-2014, 01:32 AM
Gordy's Avatar
None of the above no chemicals, overheating or rough usage, They are stiff and i have had them in a couple of directions, The blue rubbery tubing has just frayed and the motor is now going from mbx6 tekno into mbx7eco, so i would like to replace the protecting tube! Bit fussy like that!
Cheers Gordy
Gordy is offline
Old 02-09-2014, 01:35 AM
Gordy's Avatar
Thanks for replies,
I would only like to replace the protective tubing without altering anything else! Do you have any idea as to where i can find some??
Cheers Gordy
Gordy is offline
Old 02-09-2014, 01:46 AM
dtr
dtr's Avatar
Originally Posted by Gordy View Post
Thanks for replies,
Just google for shrink tubing. Any hobby shop or electronics shop will have them. You have to measure the thickness of the bare wires but you will need something in the 2mm range (diameter after shrinking).
dtr is offline
