? about setting up my vxl slash with airtronics mt4 >
Old 02-07-2014, 01:31 PM
Default ? about setting up my vxl slash with airtronics mt4
I just ordered a airtronics mt4 to go with a D8T racer i just bought. My question is what would i have to do to change my traxxas radio over to the new mt4 on my 2wd vxl slash? I know probably just buy an extra receiver but is that all i need and what do i do to set it up on new radio?
Bsud is offline
Old 02-07-2014, 01:55 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
read the Manuel when it comes. tells you exactly how to bind a new receiver. (and yes, you will have to buy another receiver, if you want to have separate receivers in the 2 different vehicles, without swapping)
ThePanda is offline
Old 02-07-2014, 01:57 PM
Thanks!
Bsud is offline
Old 02-07-2014, 01:59 PM
ThePanda's Avatar
aitronics mt4 is the best! you will love it. it also tells you how to set up telemetry.
ThePanda is offline
Old 02-07-2014, 02:17 PM
MT4 is tops
RcTc02 is offline
Old 02-07-2014, 02:22 PM
Ok let me ask does the two receivers have to match or can i use the mx-sport receiver because the slash will not have the telemetry just my racer. The alternative receiver also would be cheaper!
Bsud is offline
Old 02-07-2014, 02:54 PM
ThePanda's Avatar
im not sure if those are compatible with the mt4, you might wanna check that.
ThePanda is offline
Old 02-07-2014, 03:00 PM
i think they are just wasnt sure if i could run one in model number in one and different model number in other. The telemetry ones are 100+ and the others are cheaper. I will already have one that comes with radio but i was gonna purchase cheaper one to run in my slash.
Bsud is offline
Old 02-07-2014, 03:03 PM
ThePanda's Avatar
the "memory slots" only store radio settings. You will be able to use multiple as many receivers as you could want, but if you have different settings on one vehicle (say servo reversing) then you need to select the different "memory slot" on the radio.
ThePanda is offline
Old 02-07-2014, 03:12 PM
ok so i set one vehicle up on one memory slot and the other car on another?
Bsud is offline
Old 02-07-2014, 03:14 PM
ThePanda's Avatar
yes. then you can use either receiver, but if you want the setting on one memory vs another, you will have to change it over.
ThePanda is offline
Old 02-07-2014, 03:24 PM
so basicly saying which ever car im runnning i will have to go in a change memory channels. or am i confused on what your saying
Bsud is offline
Old 02-07-2014, 04:00 PM
ThePanda's Avatar
Think of each "memory" in the radio like a language. And then the receivers are like the locations where the languages are spoken. Ok, got that? Now, you can go to basically unlimited locations (unlimited receivers) but you will need to then know the language to speak at the country you go to (memories in radio)
so if you have x car you should select y memory with the cars specific settings to work correctly. You could use different memories with different setting, but if it not specific to the car, it wont work well. (As endpoints, expo, and other settings would not be optimized to the car)
best i could come up with
ThePanda is offline
Old 02-07-2014, 05:40 PM
That helps! It will be better understandable once i have radio in hand and see how everything works.
Bsud is offline
Old 02-07-2014, 07:20 PM
Any FHSS-2, -3, or -4 Airtronics receiver will work with the MT-4. The MT4 is a great radio. The manual gives really good instructions on how to bind the different receivers.
I've had one for about 2 years now and love it. It's a great radio.
Riverbluff is offline
