Schelle Racing Innovations
#181
#182
We offer the B5M set, TLR 22 Mid set, and soon all the individuals in 4-packs. Link here: http://www.schelleracing.com/Schelle...um-Ti-Products
#183
Any chance for black aluminum B5M servo mounts with chamfered edges and black shock parts? I'd love to have an all black B5M and T5M!
#187
Is there going to be another run of Kyosho steering racks?
#188
#189
Soon, we are announcing a new line of 12mm pistons specifically for the AE V2 shafts with "screw on" pistons. Those new pistons will be available 2-3 weeks.
For those upgrading their existing shocks, please note that the FOX Kashima coat shock bodies will also work fine with the e-clip shock shafts and pistons.
#190
@ Eric- The Kyosho rack is delayed for a re-design, we are changing away from flanged bearings. Sorry it will take until late June or early July.
#191
Schelle B5/T5/SC5 Offset V2 Topshaft Set
The new Schelle offset V2 topshaft set for the Team Associated B5M, T5M and SC5M was designed to shift the motor weight closer to car’s centre line. The set utilises a 3mm extended hard-anodised aluminium top shaft, spacer tube, and a 3mm carbon fibre motor plate spacer to shift the motor plate and slipper unit in the car. This results in more stability and symmetric turning forces. The set fits any V2 3-gear or 4-gear gearbox.
Source: Schelle Racing Innovations [schelleracing.com]
#192
Hi Kurt, does the newer B44.3 -3mm chassis set work as a conversion for the B44.2 also?
#193
For a B44.2 to run the new chassis, there are quite a few AE parts to get: B44.3 motor mount, center bulkhead, B44.3 center diff, center rear bone, rear top deck. Then you will have a in-between car ... a B44.3 without the front and rear gear diffs.
#194
Thanks for the thorough answer, Kdub.
