Speed Passion Motor Wiring >
Old 12-30-2013, 09:46 AM
heinen81's Avatar
Angry Speed Passion Motor Wiring
Hello, I did a search first, with no luck.
I just purchased the SP Champion Edition Reventon ESC and 17.5 3.0 motor combo... the instructions for the wiring were vague.
the motor has 3 gold female plugs sticking out from the end bell, while the esc has 3 90* male plugs, which are size on size to the female plugs... no way they will plug in. Anyone come across this? thanks.
heinen81 is offline
Old 12-30-2013, 10:01 AM
Trader Rating: 38 (100%+)
I'm not sure I follow what you are writing, but the motor might have the "female" plugs in the motor. You just pull them out. Once you have everything connected it makes things easier to swap out motors with another SP one. No solder iron
Here's a picture of a SP motor soldered up.
Nexus is offline
Old 12-30-2013, 10:06 AM
heinen81's Avatar
thanks! i was saw those pictures as well, and wondered if they were just plugs in the motor right now as well... was just nervous to grab a needle nose and try pulling them out in case I was wrong! thanks again!!
heinen81 is offline
Old 12-30-2013, 10:37 AM
No problem.
You can also find out Speed Passion specific thread if you need any other help.
Nexus is offline
