Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Every single FT part they could come up with is already out. People would just save some money when buying a new kit. They could improve the slipper or at least put a vented 2 pad back in the car. Because not even the team drivers use the VTS, lol.
Suspended
I was kinda thinking the same thing, seems like the car is a little on the heavy side. I haven't weighed it yet as I don't have a scale anymore.
B5R arms and shock tower
3mm trailing axle insert
1mm on each side of the caster block
1mm bump steer
arms flat ride height
For the rear I changed:
B5R arms
2* antisquat
0.5* hub insert
"A" ballstud hole, using the B (2 hole) link insert, B inserted in the down position
Forward hub spacing
0mm inner ballstud spacer (camber link)
1.6 Pistons, 30wt oil, 3 limiters
bones level ride height
This really wakes up the front end. It has very aggressive turn-in. When I have more time at the track I will experiment with front tires before changing anything.
Other than the slipper, what are some of the must haves you are all running off the stock car?
I have heard talk of clamping hexes for the rear, what benefit do those have? My hexes seem to stay locked to the pin.
I know the rear hub ball cup mount can flex on the composite side causing some backing out. Though loctite seems to take care of that.
Suspended
Okay so I have been trying to get through all of this thread and filter through all the drama...haha I am wondering where the grub screws are being installed. Sorry for it has been answered a million times but Hundreds of pages of reading is mind numbing and so I figured I would ask and then go back to my reading
***Looked up the Manual online since I bought my buggy used and found it... I will continue ready.. Only approx 250 more pages to go...haha***
Super Moderator
Trader Rating: 31 (100%+)
When rebuilding the diff what oil are you guys using? The kit oil or something different?
