Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#1426
I will probably get lunsfords, the front pin brace and rear hexes. Thats what $50? So after the tower discounts, I will have like 270 in the car. If I decide to put on the rear suspension holders, that will put me slightly over $300. Still less than a 22 buggy and miles below a rb6 and slightly more than a serpent (also come with very little option parts). So I am not really seeing an issue. The xrings, I will just put in on my first shock rebuild. Most people that ran the b4.x have some machined pistons for tuning, so that wont be required for many people. The gold shafts? I will replace those "IF" the silver shafts are an issue. I am not really a fan of the color gold anyway. Since I race stock, most of the alum bling will only make me heavier, so I may skip on those, unless there is a durability issue. Dont get me wrong, if they released the FT kit at the same time, I would probably just get it. But at the current price point, I just dont see an issue. I mean it is the cheapest 2wd buggy that is actually raced at events. And it has threaded bigbores, 3 disk slipper, carbide diff balls, and captured CVA's. And if you have ever had a cva/cvd come apart, you know that is very nice.
#1428
Also, in that interview. I found 2 things interesting.
1- his explanation of the arms and what they change.
2- His reasoning for not making a convertible car. He basically said the the RM config would have suffered due to chassis flex and positioning. Remember, they went alum chassis on the MM car because it requires X amount of flex, that they could not achieve with plastic and webbing. They wanted to go plastic, but could not make it work. I beleive AE gave these cars a best effort and didnt just slap it together for sales.
#1429
This was posted over in the B5 thread...
Detailed pics of both cars from Neobuggy and an audio interview. Finally get to see the bottom of the chassis.
http://www.neobuggy.net/2014/01/22/e...lead-designer/
B5M has been preordered, now I just need to figure out what crap I am going to put in it.. And which chassis protector I'll be using because there is no way in hell I'm scratching the bottom of that aluminum The bottom of that rig looks suuuuper clean!
#1430
in one of the interviews a designer said the ft version wont have anything that changes performance at all and just a few parts that are only different because tey are alu. and blue
#1431
- Graphite plastics - hasn't been the case since before the B4.1
- Threaded shocks - comes with this
- ti turnbuckles
- coated shock shafts
In recent years "FT" has added alloy rear hubs and hexes, both of which are unnecessary (If you're not going to adjust rear width the pin drive is adequate).
Also interesting to note, when was the last time AE offered a "Team" level B4 kit? If I'm not mistaken, that went away with the release of the B4.1, if not before.
Factory Team = strong Kool Aid.
#1435
Super Moderator
Let's outline what "FT" means or did mean.
- ti turnbuckles
Now if you want to debate what made up a Factory Team Kit based on history then yes you are almost if not 100% correct.
#1438
You have to understand that the current lipo stick packs were made to fit an area the size of the old 6 cell nicd/nimh packs. Now that lipo's can be made in basically any size you should start to see companies design a car to be the most efficient in weight and layout. And that means the part that weighs the most is going to change as well.
#1439
Can someone make the case for the square pack over a shorty pack? I don't see why anyone would want the square. Unless the car is unstable with a shorty and needs the brick in there?
#1440
