Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Anyway, after running MM for about a month solid, I gave my RM setup a try again last night. It took some getting use to in the corners with the pendulum returning. But once I got the feel. I turned some very good runs. My best runs on this layout. The RM car is so much easier to drive hard in 17.5. The MM is better in sweepers, has a nicer feel in the flowing sections and jumps flatter. But it likes to do crazy shit when I driver harder. So for now, the MM is shelved and the RM is my go to.
Got hit by an 8th scale square in the back.
Car was fine but when I stopped to get off track, hit throttle to move a few feet and no go. Back at the pits re calibrated lrp works esc, good, back on track was good then went to like a derate feeling, not full power on the straight with full wood.....esc or motor?? Going to take out esc and check sensor wires motor, etc. which is no fun in B5m but thought I would throw out to see if anybody has ideas.
[QUOTE=Cridd;13486553]Got hit by an 8th scale square in the back.
Car was fine but when I stopped to get off track, hit throttle to move a few feet and no go. Back at the pits re calibrated lrp works esc, good, back on track was good then went to like a derate feeling, not full power on the straight with full wood.....esc or motor?? Going to take out esc and check sensor wires motor, etc. which is no fun in B5m but thought I would throw out to see if anybody has ideas.[/
If your having problems , was the ESC flashing trouble codes ?
Checked it out more, says motor or drivetrain lock. Going to put new motor in and see if that fixes it.
@ Roar Nat's in Orlando
MikeS & the Tacompton
B5M
19/5:09
Oyeah......
B5M
19/5:09
Oyeah......
[QUOTE=Wild Cherry;13486476]
I don't want the silencer I don't like the back of the roof and back side window area... I like the serpent body the way the car looks like the finisher, but has the fin on top... My question is will the serpent mid motor body fit the b5m?
Hey I'm very interested in the serpent mid motor body. I like the way it's a cross between finnisher and silencer. My question is will it fit on the b5m? No one at the local tracks run serpent. Ae, losi, Kyosho, and a few durangos but no serpents. If anyone out there can help me out I'd much appreciate
the Silencer is prefered for its handling & designed to fit a b5..
Buy one, test fit it and let us know if it fits.
Don't want to waste the money to see, was hoping someone at one of the tracks out there has a buddy that has a serpent, could drop it on and see how close it is and what doesn't fit...
A friend wanted a phantom on his c4.2, we checked around to find that b5m doesn't fit it, however the rb6 body did. Saved him $22 on a mistake
it could be a few things, but since your racing locally, I will say it is tires. I kn ow, I know you bought the right tires. SRS and W3 need special tires. what does special mean? well broken in tires and foams. Many of the fast guys at srs are running clay slicks. But, if you dont have it sorted out by next weekend, I can have a look. I had a local drive my RM car last night at w3 and said it was very smooth and easy to drive and turned well. If you like, you can try my car next weekend. I will be at SRS all 3 days for the grand opening series event.
[QUOTE=Ostach24;13486955]
Be care full what you wish for,
what you do not like is what makes the Silencer more popular.
Adding more down force on the rear is not helping the handling on the B5.
Maybe the Serpent needs , not the B5 though.
That's why the new Silencer is only copy of the Centro Silencer.
Track time has been proving that design is a winner.
Maybe ask the Serpent boys if a b5m shell fits a Serpent ?
I am pretty much running the stock setup on mine for camber links. Currently, my hubs are back, I have 1/2oz under the rack, I run 1.6 pistons front and rear, 30/27.5 oils and 2 limiters front and 1 limiter rear. otherwise all stock shock and camber locations. I also run the shorty in the forward position with a full sized servo.
SRS was closed today. They are redoing the track so there should be a new layout. They said that it might be ready tomorrow afternoon. I'm hoping so. For warehouse 3 what kind of tires do you use? I think I'll go out there tomorrow if it isn't ready. I'm itchin' to try out the new buggy on a track.
dude, tires are "special" at w3, lol. I am running half gone typos in the rear ss and gone gone m4 suburbs in the front with 3/4 rear foams and my tires have been sauced a couple dozen times. If you goto w3 and want to get tires, I would go with typos front and read in SS compound. pick up some sticky kicks blue. clean and sauce the tires after every run. they should start to come in after a few packs. typos already have a pretty low tread. ions are good, but have a lot more tread and take a while to come in naturally. dirt web greens are terrible. no mater what you get, you must have Super Soft tires.
would like to thank everyone for the set up suggestions. i ended up returning the buggy to near manual set up. i shortened rear links, took out all ackerman, lowered front ball stud height and the car hooked up great. 63 entries today, 3 mains of buggies. qualified 4th in mod buggy a main and finished the main in 4th. i have never did this good in al the years ive been racing. all the mid motor guys were like wow that thing is hooked up as im taking their lines away in the corners and passing them in the air! lol
