Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 07-29-2014, 07:09 PM
  #12616
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by Bubonic-X
I got the Schelle slipper before I was at 32/69 so ima try 33/72 what you think?
I am 31/69 on my car. I temp out at 130-140. But I am using a reedy, so gearing might be a little different. timing too
Wildcat1971 is offline
Old 07-29-2014, 07:59 PM
  #12617
Trader Rating: 515 (100%+)
We run 69/30-34 with a 17.5 on our track depending on what the layout is like. For the life of me I do not understand why people run a slipper in stock. Even on wet bluegroove I don't need it with a 17.5. Have all you slipper running 17.5 guys tried to run an eliminator? It's $20 for the Exotek hub and a gear. Try it you'll like it.
QDRHRSE is offline
Old 07-29-2014, 08:08 PM
  #12618
Trader Rating: 17 (100%+)
It's much more important when the track is loose then on your "wet bluegroove track." Running without a slipper is NOT something I would want to try on a track that has any wheel spin. All that will do is make your car harder to drive, no thank you!
Kave is offline
Old 07-29-2014, 08:19 PM
  #12619
Tech Legend
Wild Cherry's Avatar
Originally Posted by ryanpatrickgore
3 sets of gold barcodes with red foams in rear. (Just broken in, 1/2 way gone, and trash can tires. All the fronts match and are good. Just need front springs to finish setup. I wish I didn't sell my red front k-springs, have the rear golds still
Red's
are hanging on the wall.
Tires sound ok, 1/2 ways we save & practice in new ones.
You know I will gw there.
Wild Cherry is offline
Old 07-29-2014, 08:27 PM
  #12620
Originally Posted by Wildcat1971
saddles and sq are the same shape and weight. My saddles were 278 grams. My shorty is 214. A sq just has the built in balance port and you dont have to use a jumps, so probably less IR. Saddles are nice also, because they can be used in 4wd buggies. I used to have a b44.2, so that was why I owned a saddle in the first place. But now even 4wd buggies are going to shorties, lol.
This is outrageous....I'm breaking out with my scale....that I just bought and need a reason use. I'm gonna weight 3 smc packs, a reedy pack, and my old TP5400 saddles:
SMC 5800 Square: 274.2g
SMC 4600 Shortie: 211.8g
SMC 3500 Shorty: 152.6g
Reedy 5800 Square: 281.5g
TP 5400 Saddle: oh snap, I weighed it twice......322.9g
I have a Reedy 4100....I should just weigh that one too.
QDRHRSE is offline
Old 07-29-2014, 08:47 PM
  #12621
Trader Rating: 166 (100%+)
what is the width of the updated crush tubes. I have 2 kits and I am curious to which I have. kinda a pain because I have no idea what the LHS, amain or tower have in stock, lol
Received 2 kits from tower, both have the old crush tubes. Hopefully the second mid motor I ordered locally comes with the right tubes. Axles in both kits I have now are loose.
jpcopeland1 is offline
Old 07-29-2014, 09:09 PM
  #12622
Where can one find a comparable piston it the machines 3X1.4 pistons sold out everywhere I've looked?
Old 07-29-2014, 09:21 PM
  #12623
Trader Rating: 48 (100%+)
i run 32/72 @oc/rc gives plenty of speed and pop to clear jumps easily( running schuur speed v1 motor)
NitroLuver is offline
Old 07-29-2014, 09:36 PM
  #12624
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Looks like AVID has a few left in stock
http://www.avidrc.com/product/5/acce...cessories.html
JDM_DOHC_SiR is offline
Old 07-30-2014, 05:40 AM
  #12625
I was using the venom 4500 saddles, lol
Old 07-30-2014, 05:57 AM
  #12626
JatoTheRipper's Avatar
How can you tell the old crush tubes from the new crush tubes?
JatoTheRipper is offline
Old 07-30-2014, 06:04 AM
  #12627
Trader Rating: 22 (100%+)
Now weigh a NIMH. 390 grams. We have it so good and easy now with lipos and brushless.
GTSSTANG is offline
Old 07-30-2014, 06:42 AM
  #12628
Does Schelle make a 69? Or your not using the schelle in the RM?
Bubonic-X is offline
Old 07-30-2014, 07:21 AM
  #12629
double post
Old 07-30-2014, 07:29 AM
  #12630
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
I would never lock or bypass a slipper, its there for a reason. Its there to protect your drivetrain when u land from a jump and are on the gas. People thinking its simply a traction aid are so very wrong, it NEEDS to be there.
Trevor Williams is offline
