Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
hey wildcat...
ya I could tell it has tons of steering...
ok.. here this might help. I know this sounds opposite of what you may think.. but going to a softer front and rear spring will slow the cars reaction.. and also depending on your temps outside there.. maybe go up to 37.5 in front and 35 in back but leave the same pistons.. use the inside holes on arms both front and back.. this also changes the leverage points and slow the cars reaction both front and back.. go inside on shock towers as that will make it more progressive in the suspension and feel better on jumps.
use the 25 deg. front block.. if you have the 30 on there it quickens the steering feel.
in back run your hubs forward.. this will give the most rear traction and also slow the rotation of the car in the corners allowing you to carve them more. same with running longer rear camber locations.
not sure what motor and gearing your using.. but if your using a shorty battery try running it all way back or with one small spacer behind it. I actually took a extra big pad and cut my own that are half as thick as the small ones for even finer tuning.
also on tire foams.. if your running a closed cell foam it will transfer the energy quicker.. you may try an open cell foam or a 2 stage foam. in fronts I actually really like stuffing in a truck tire foam and I just trim it to the width of the buggy tire first.. this puts more foam in the tire rounding it a little helpin it tract better and smooths out the corner speed even more as it rounds the tire a little more.
oh and congrats to mikey Hudson who just won the nw nct rd 4 series up in Washington.. he beat some of the best drivers in the nw using a b5m . this is only his 4th time driving the car. I helped him get it dialed in and he is loving the car outdoors.
if he hadn't had electrical issues he would have won regionals with the car too.
25+5 caster check
Rear hubs forward check (rm arms)
battery back check
rear shocks inside/inside check
open cell front check
I actually had longer rear camber links and longer fronts. this week I went to the "standard" camber links. I went from +3 to +4 on the spindles to try and calm it down and took the 1.4s out of the front. The car seemed to roll a ton with the 1.4s. I was lifting the inside front wheel.
I will try some of the things you suggested.
interesting going to heavier oil and lighter springs. I see where your going with that.
battery back check
Twitch,
stiffer rear spring, softer front spring, softer oil in rear or more holes in piston, stiffer oil up front, long wheelbase, battery forward, add weight at the front.
You guys talk about twitch like its the same as removing steering. It's not.
What are the benefits of the captured ceramic thrust bearing from Avid over the stock one? Easier to adjust the diff?
I have a b5m running on a clay indoor track that has a little push going into corners and does not have the same low end punch as the other 17.5's. I was told to lighten up the tranny with an aluminum top shaft, mip puc system, nova slipper, bfast diff and b5 front a arms and shock tower. Any suggestions or advise if I'm going in the right direction or additional mods. Thanks.
Where did you get the thin lead?
If you try what we are doing ?
Your ride will be a lot smoother and consistent in the corner.
More grip too...
BTW
my ride is at 59.6 oz ,1672
Lighter is not necessarily better...
More weight under the battery will help you more then lighter parts every where else on the car ..
Huge difference...a game changer in my book
More grip too...
BTW
Are you guys running hubs forward with rm arms on the mid motor?
well, imo not fighting with those tiny balls during the rebuild is nice.
Some people on here aren't too kind. Any who, if you switch to flat front arms and tower it will only make it push more. I don't know how the traction is at your track but put a small foam closest to the motor to move battery forward a lil. Make sure your running the same brand tires front and rear and same compound
I have found that black frt with green rears is predictable and is alot more controlable mid to exit
PLEASE BE ADVISED BAD DRIVING TO FOLLOW. lol I decided to run both my MM and RM cars in mod tonight. Both cars gave me issues, but the issues were different. I ran the MM in heats 1 and 2, then switched to my RM car in the main. I used the same motor and same tires. The RM car pushed but was easier to drive and gave me a higher consistence and was .75 seconds faster per lap for a top 10 lap average. The top 5 averages were about the same. My hot lap came from the B5M, but is was a hand full to drive. Tons of steering and very twitchy. A poorly adjusted slipper in my RM car, made anything that needed instant power a fail. You will see me struggling with the step on step off and the short run up double on the right. I am still unsure which car I like the best. The MM is fun to drive and it is very aggressive and corners on a dime, but feel very unstable on jumps. Anyway, enjoy the poor videos of my poor driving.
BTW. I was runnign with Spencer Rivkin, Tanner Denny and Tommy Hinz. So of the 5 drivers in mod, 3 are factory team drivers....lol. Also, I may have punted them at one time or another...oops my bad.
A Main Pink B5 ream motor car
http://youtu.be/sreCdc5yjBQ
Qual 2 green/purple B5M... Also, I was a lap slower than my first qual with the MM car. The rear was loose.
http://youtu.be/XcfymT7wBto
