Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#9376
The less expensive screws won't stand up to much wear & tear .
After being used for a short time they will need replacement , thus the Lunsford will prove to be the better value with time .
After I wear out the blue switching out for the better quality.
#9377
I went with the blue Ae and after wish I had gone with the Lunsford instead.
#9379
So I was told there are alumium cvd made my mip that just replace the stock one and I don't need to spend 90$ on a puck system
#9380
#9381
#9382
Update:
Removed the triple Ae slipper.
& the B5 slipper spring.
Replaced with vented twin pad & heavy duty sc 10 slipper spring.
Next is the removing 1 mm from bump steer.( was highly suggested to do)
Won't do today , need to run with out tonight for base test and then change for Fridays club race .
#9384
#9386
http://www.pitboxhobbies.com/index.htm
Go to metric screws and go to titanium. Great screws and will be shipped from Indiana! You might recognize the car on the front page as well
Per lunsford website: What makes Lunsford titanium screws so special? All of our screws are machined from domestic 6AL/4V titanium -- made in the usa.
#9387
tlr does fit but maybe a little too long when compressed. ae is flat at the end and tlr is round. just need to shave flat like ae one and/or add an o-ring to the shock shaft so it doesn't compress all the way down.
#9388
Update:
On the rear camber links are u using the alum brace with with 4mm on the low side. (that would be +2 from stock)
thanks
#9389
How do you remove 1mm from bumpsteer? Right now there are no washers under the stud (at least stock setup) are you talking about on the rack (adjusting Ackerman)
thanks
thanks
Yes ,using 4mm on the low side with the alloy rear camber brace.
#9390
