Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#9092
Well no you could use the shorter stud in all the holes right? To me the larger issue is that if you're using a 6mm stud with the 3mm spacer that means you need to use a 4mm stud with the 1mm spacer for the lower position that is often used on high grip tracks. They don't make a 4mm stud so it would have to be cut or ground.
#9093
edit: http://www.teamassociated.com/parts/details/91451/
#9094
#9095
That's the way I read it too. Anyone have some hard hubs they will hook me up with?
#9096
There is a 4mm stud available!
I used the 6mm stud with 1mm washer this weekend. It will bind in one or two of the holes tho.
It's a great part and they are extremely light for alum hubs!
#9097
#9098
#9099
Just posted this in the mid thread and wanted to add it here also. This about the Aluminum hubs.
We should have included a slip of paper to clear all this up. Sorry.
This is the way it should be.
The etched 0 faces the shock. This means rear motor it is forward and mid motor it's back.
3mm of ball-stud spacing makes the high position. 1mm is the low. The kit hub has 5 link length options, with the aluminum hub you no longer have the longest/ outer ball position. Be careful about the thread length ball stud you use, if it's too long it will crush the bearing in a couple of positions. 6mm thread is recommended with 3mm spacing.
#9100
I'm building mine now what's up with the front axles blowing out and what do I need to do to prevent it the parts are like gold right now. As you all probably know.
#9101
So...My cups are just not loosening up. I had kinda hoped they would break in a bit. I tried the squeezing method, but it was a very small improvement. I am thinking about moving to 4.8x3mm studs and cups for most part. Aside from the goofy steering link. Has anyone found a sure fire way to free up these stock cups? Otherwise I think I might try the tlr cups and studs.
I run them on my 4.2 and on my 410 and after a year now a few need to be replaced. The cups are so strong I bent a rear Lunsford turnbuckle and the cup still requires tools to pry it off!!!
#9103
Any disadvantage of the having the hard front and rear towers since 91516 and 91518 seem difficult to find?
#9104
What does running the B5 rear arms on the B5M do for the car?
#9105
yeah, I have a bunch of new cups and some studs from my tlr cars. hence why I said those. I will try to polish the current ones, but if that is not good enough, I will use the tlr ones. I like that were can easily remove the current ones. As I disliked drilling out the tlr style cups.
