Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#7473
You don't need those setscrews. Just put a dap of tire glue or any glue on the inserts that go into the hubs (front and rear) and you get rid of slop. Also saving grams of weight which you want to do wherever you can since the b5m is such a heavy car.
#7474
2
#7476
What holes are you guys using on the stock wing? The forward or rear holes?
#7477
#7478
Can anyone think of a reason why I can't use a b4 Diff gear? The b5 gear is wider but it's the same number of teeth. The Difference is only about a 1/16th
#7479
I'm running a jconcept wing now. I'm going to switch to the stock wing it came with. I noticed it's a totally different shape. Wondering if that will make a difference.
#7480
#7482
is the body pre cut
#7483
Did you trim the front of the wing then so it doesn't hang so far over the body that way?
#7485
losi is not good at trimming
