Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#7428
I did the crush washer mod on the akerman rack and works great. Never had a screw back out on the aluminum rack. There needs to be a crush sleeve on the long screws that thread into the top plate. The mod was on B5 Nation FB page.
Basically you use the 1mm blue AE ballstud washer between the bearings in the akerman rack. you have to ream out the hole between the two bearings enough to allow the washer to fit. it was a 5 min mod.
#7429
hows it to work on?
#7431
Anyone have a setup for carpet? Other than the ones on patitt rc.
#7433
Associated B5M Aftermarket Parts
B-Fast R/C
R66 - B5, B4(.1 & .2) T4 (.1 & .2) Diff Rings (one set of two rings) Associated part #7666
Advantage Hobby
T720C - 1/10 Bobcat 2WD Buggy Fr Clay (2) QTY: 1 (Included Open Cell Insert)
T771C - 1/10 Rattler || Buggy Tire Clay (2) QTY: 1 (Included Open Cell Insert)
F750 - 1/10 Buggy Rear Closed Cell Inserts (2) QTY: 3
F720 - 1/10 Buggy 2WD Front Closed Cell Inserts (2) QTY: 3
2736-02 - Velocity 2.2” Hex Fr Ylw Whls w/12mm Hex (2) QTY: 3
2736-02 - Velocity 2.2” Hex Re Ylw Whls w/12mm Hex (2) QTY: 3
Lunsford Racing
2006 - Associated RC10 B5 Punisher Titanium Turnbuckles
7052 - Associated RC10 B5 Titanium Front Axles
ACER Racing
B5M Ceramic Nitride Pro Series Bearing Kit - Qty.8 - 5x10x4mm, Qty.2 - 6x12x4mm, Qty.4 - 10x15x4, Qty.2 - 6x13x5, Qty.2 - 5x8mm and Qty.8 - 3x7mm (Stainless)
N015 - Ceramic Silicon Nitride Balls 3/32” 14 ball pack
Team Associated
91427 - B5 Aluminum Top Shaft
91493 - Factory Team Low Friction X-Rings (8)
Absolute Hobbyz
CRP-0004 - Competition Suspension Blue 12mm VOP Piston Set (4)
Superior Hobbies
JCI307605 - Dirt Webs 2.2” Buggy Tires Gold (2) QTY: 2
JCI307705 - Dirt Webs 2.2” Buggy Fr Tire Gold (2) QTY: 1
JCI2150 - 69T 48P “Silent Speed” Machined Spur
ASC1105 - Shock Lube, Green Slim
ASC9603 - B4 Slipper Pad
ASC7485 - FT V2 Slipper Hubs
ASC7486 - FT V2 Slipper Spring /Washer
Avid Racing
AV1010 - Associated 12mm Shock and Turnbuckle Tool
ROB-RRP-1333 - Robinson 33T 48P Aluminum Pinion
ROB-RRP-1334 - Robinson 34T 48P Aluminum Pinion
Here are all my upgrades I have ready for the B5M when it arrives.
Advantage Hobby
Lunsford Racing
ACER Racing
Team Associated
Absolute Hobbyz
Superior Hobbies
Avid Racing
#7434
For anyone who is interested in the alloy rack; I just received mine from Amain today and it looks like there are two 1mm crush washers included with my rack........I looked at some pics of packaged racks online and saw no such washers, so perhaps AE has included them to correct the issues. I haven't installed the rack yet so I can't verify for sure, but the washers are clearly unique to the aluminum rack.
You have something different there. I have the first gen rack and there were no crush sleeves for sure.
Post when you get it installed.
#7435
Wondering about the Schelle (or Avid) 66 tooth spur for stock(this question is right in your wheelhouse Matt Trimmings). Would moving the motor forward help, not help, handling difference for the new buggy... and would the motor actually slide forward enough to mesh? Seems I bought one for my B4 a long time ago but had to gear it taller than I liked just to get it to mesh and went back to a 69.
Forgot to also ask what's the story with the 64 pitch, 88 tooth spur they have listed? Thanks for any insight.
#7436
I just got mine today and they have the little aluminum washers too. Haven't opened them up yet but they look like ball stud washers at a glance
#7437
Not me selling them, but I might buy one, thought you guys might be interested.
http://www.ebay.com/itm/RC10B5-CNC-M...item51bb285967
#7438
#7439
Looks great! Mine should be here any day now.
#7440
Where do those washers go on the rack???
