Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#7291
So I saw on Bfast website they have a rebuild for the b5? I was told the other day that there is not a rebuild out yet.
#7294
Caged thrust bearing)when I built my MM. It's silky smooth but I personally
Think if you take the time and details needed you can build a diff with the stock
Parts just as smooth.It does take some time working the rings but it can
Be done.
#7295
I am looking for some help...I am trying to tune my new B5m for an indoor carpet off road track. The buggy is awesome but it has a bit of high speed push in the front that I can't get rid of. I am running the following settings:
-1 Camber all around
2 degree toe out
40 weight front / 32.5 rear oil
Mini Pin rear tires, Cut Stagger slim front
Ride height is around 16.
Any suggestions to get a bit more high speed steering?
Thanks...Scott
2 degree toe out
Thanks...Scott
#7296
2 degree toe out
Thanks...Scott
2 degree toe out
Thanks...Scott
In addition what springs are you running. You can increase spring rate in the rear to reduce traction roll and increase steering (reduce push). I would also reduce your front oil weight.
#7297
Caster is 5 and the trailing axle insert is 3mm. I tried to drop the oil in the front down to 37.5 but it seemed to push a bit more. Also, how about the shock mount points...any suggestions?
Thanks for the help!! Scott
#7298
I dont want to offend anyone but if you cant get a RM car around the track then MM probably isnt going to help you. GEAR DIFFS, Unless your on HIGH HIGH bite astro, then i dont think its worth messing with, or its for lazy people? I run on high bite dirt/clay that MM car will wheelie down the straight and we all run ball diffs w/ no issue. we will run them for 6 months w/ no gritty feeling at all. Its all in the build and break in and final sttings. I love the B5M, great car, as good or better than anything available IMO. I have owned 22 2.0, RB6,and the B5M and I prefer the B5M for its steering characteristics. I wont bore you fellas anymore but just my thoughts!!
#7299
This is more of a general setup question for the Avid Triad, but I set it up on the bench a little loose to then try on the track, and I don't really hear it slipping like I did with the VTS. Are there any setup tips for the triad?
#7300
I've never heard my Triad slip like a 2 pad system and never heard the VTS specifically (perhaps this last weekend but I can't be sure). For setup I follow the AVID instructions and tighten to the point where it is hard to run the slipper with the other wheels on the bench. This method has worked very well for me as a starting point. If you want to go a little looser from there for specific track conditions then you can but personally I start there.
#7302
From my experience it loosened up the rear end.It definately takes that planted feeling away. With the brick in it I was planted in the rear and had a slight push so I changed my setup to get more steering. So you'll be doing some tuning depending on the pack you choose . They have total opposite feels
#7303
#7304
Question. I put the +3 on the front spindles, went to 1mm on the ackerman and wanted to center the hubs. The kit seems to only come with the 2mm plastic spacer and not 2x 1mm spacers. So I went into my box of ballstud spacers and and pulled out a couple 1mm alum washers. But after calipering them, they are only 1.98m combined. The plastic was 2.02. Does not sound like much, but the front end went from slightly tight to b4 slop. Tonight I plant to see if I have any spacers that are actually 1mm, but I would think .99mm would be fine.....on the upside, any binding I had in the front spindles went away... What are you guys using to center the hubs with the +3mm spindle config
#7305
What holes are you using today?
