Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#6961
Leigh
C'mon man i don't know why you all expect perfection from these kits. Some are tight in one place then others. Transmissions. Steering components, arms they are susceptible to some degree of bind. It's called hand fitting and making it smooth. It doesn't just happen. All the kits losi, xRay, Durango come with some degree of hand fitting. It's part of the process.
All the kits I have ever built required it. From 12th scale to all the b kits. To 8th scale. Just like you said it will get looser as you run it. Why does it warrant a complaint. Put a b4.2 together and see how bad it was. This car is butta compared to the b4.2. Jump all over me guys I can take it.
Jake
Jake
#6962
#6963
Anybody have some insight if I move the spacer from front to back and what that will do overall to steering and any other changes that could happen?
#6965
#6966
In the back of the manual there are settings and recommendations for trailing axles and how to match that to Ackerman settings. Changing trailing axle you should change Ackerman. I had never played with axles so it was news for me also. There are also caster block recommendations too which I have not played with to match my 2mm trailing set up.
#6967
Ceramic vs Carbide ( tungstan )
Putting MIP puck system in my B5rm, Looking to upgrade my diff balls. Ceramic or Tungstan Carbide? I heard Ceramic won't flat spot if you spin diffs and you can reuse them........Looking for opinions
#6969
#6971
"That's strange that so many of you have had issues with your Reedy packs - I've had my shorty for 2 years & picked up a lightly used saddle pack for my B5 and have always found Reedy packs to be strong packs, albeit, at the top of the battery pricing scale - so far for me, they've been well worth it."
Same here, I've spent the extra coin on the Reedys cause the cheaper ones crap out on me. Had Reedys for 4 years in all my cars. No issues what so ever.
#6972
About the spacers on trailing axles, you can reduce the wheelbase and get more aggressive car in slow turns / slow tracks.
