Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#6946
#6947
Ok guys i have the 3mm insert on the front and a 1mm water instead of the 2mm on the ball stud on the front shoch tower. And my car is still pushing. Any other tuning options?
#6948
#6950
xghost.... just doing something with the front may not take care of push.. setting up the back of the car and battery and tires make as much of a difference as anything up front. what springs r u running? shock positions? all makes a difference... you should have so much steering your trying to dial it out.
#6951
on building your kits.. take your time and sand , smooth and polish all the ball ends, hinge pins, and any rough edges on plastic.. don't over tighten things.. you shouldn't feel like you need a torque wrench when building your car.. simply tighten till it snugs and good.. no need to go all gorilla on it.
I have found that you can drive 3 kits built by 3 different people with the same setups.. and if one takes time to build the kit it will feel way better then the other 2.
#6952
#6953
1 7/8? isn't that a bit long? The B5 kit I bought came with 1 3/4 for the steering links and 1 5/8 for the camber links. I guess I don't have to worry about bottoming my turnbuckles out...
#6954
#6956
40mm Kyosho turnbuckles fit well for me. Only issue for me in the build was a user error with a gearbox spacer, car build is awesome as good as kyosho/yoko/xray and little better than losi. The low friction cups are not as free as I would like them, but I put a drop of shock oil through the holes and they are awesome now.
#6957
They flat spot if the diff slipped.
Replace with ceramic balls, they will never flat spot and can be used over & over saving you money ...
#6958
#6959
