Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#588
I disagree, most of the mods that people are doing are NOT necessary. Many folks like to try things outside the box to make their cars work for them. About the only thing I've found is the rear bulkhead needs to be aluminum. It's far from perfect, so I hope AE has worked things out with their MM.
#590
#591
We run a very efficient program here. We have introduced a novice class. Little kids get to run whatever they want. We usually cut the track short for them and do 2 heats and a main. They get to stand on the podium when they win too. I understand what you are saying. Too many classes prolongs the race day. 4x4 Shortcourse is dead here.
#592
Im just putting it out there but why buy a RM car when most of us already have a b4.2? If you need a car for Astro or high grip situations you just use the MM car? I just cant justify buying 2 cars for one class. My stance was make a car that can be converted but I admit I lost.
So Im taking that approach What do you think? Just creating dialogue
In addition to that a revised steering rack, bigger wheel bearings, etc will all appeal to the mass market. This will make for a better experience for those that don't feel like going nuts with upgrade parts in an attempt to "tighten up" the buggy (even though most of you know that lots of 4.2 owners have come to "embrace the slop") LOL.
If you have however been running a 4.2 and have spent time tightening it up etc than by all means its still a great vehicle!!
#597
Check out this Rm race car
http://www.sdjetski.com/images/Sandr...seaterblue.jpg
It seems that with the home dune buggy builders, the guys that like rear engine prefer it because of "cabin area" space and most importantly because the engine is very easy to get to and work on. With mid engine setups it is more difficult to get to the engine and there is less space for passengers. Both layouts apparently work just as well though as in the racing series you have each type winning and losing races. The argument still goes on though.
#598
Valid point. To continue the dialogue I would add that to me it sounds like AE did LOTS to eliminate the slop that we've all come to know and love.
The 4.2 is ready to rock out of the box. The only real annoyance, was the over abundance of flashing on the front of the chassis. It made the front arms bind, but only took 5 min to remove.
#599
the set screws that are suppose to take the slop out of the hinge pins don't really look to be hitting the hinge pin but hit the hinge pin insert which in turn mashes down on hinge pin (?).
good design, I guess ...
#600
Just received my Reedy Square battery. Going to check / put a storage charge on it and put it aside until I get my B5. NOTE: !!!! I was looking at the SCM web site last night. They have a square battery coming out soon! And just about half the cost of the Reedy!!! Arrrrrrrr !!!!!!
