Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree137Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-07-2014, 05:33 AM
  #5416
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Yea my LHS had 2 nearly full sets of parts for the B5 a week or so ago. I bought front and rear arms, a front tower and the caster blocks for my toolbox.
Grasschopper is offline
Old 03-07-2014, 05:46 AM
  #5417
Mason's Avatar
fancy wiring just means you'll miss a race trying to fix/replace something. been there, done that. stick with the KISS method.
Mason is offline
Old 03-07-2014, 06:02 AM
  #5418
Trader Rating: 8 (90%+)
Originally Posted by Razathorn
Whatever ackerman adjustment makes the tires more parallel at full lock gives more aggressive steering. Less parallel at full lock is smoother and less aggressive. The problem is that some racks are way forward of the spindle arms where as some are parallel or slightly behind. The steering turnbuckles are swept toward the front of the car vs toward the rear of the car as they head to the steering rack and bellcrank. Because of that difference, moving the link forward or backward is NOT THE SAME between different steering box designs. Add or remove washers and note the difference. More parallel at full lock == more steering.
Wayne
Gotcha. Thanks, Wayne!!
juicy74 is offline
Old 03-07-2014, 06:21 AM
  #5419
Originally Posted by latentspeed
New Jconcepts silencer body. Redrc.net
Proline looks better, but jconcepts looks to have better airflow.
I love the proline phantom. Any idea when the release date is?
juicy74 is offline
Old 03-07-2014, 07:04 AM
  #5420
DKSPLIT96's Avatar
Picked up my kit last night and im anxious to get it built today, anyone have any info as far as a good starting set up for high bite? Also any upgrades that should be purchased right off the bat? thank you in advance for any info you can provide.
DKSPLIT96 is offline
Old 03-07-2014, 07:08 AM
  #5421
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
Hey grant i ran mine on Wednesday at our track and the stock setup work good i used 35 oil in front and 32.5 in the back just take your time my kit went together nicely.
ridgerunner1 is offline
Old 03-07-2014, 07:10 AM
  #5422
DKSPLIT96's Avatar
Thanks mike! Im looking forward to getting it dialed in to say the least.
Old 03-07-2014, 07:13 AM
  #5423
should be a fun day Saturday should be a few B5s running this thing is just fun to drive i left my B4 at the track for sale Wednesday... not going to need it no more....
Old 03-07-2014, 07:20 AM
  #5424
gticlay's Avatar
Trader Rating: 14 (100%+)
Originally Posted by ntJeff
Got my kit built, painting the body and gluing tires now.
A few notes from my build:
Ballcups are a flipping nightmare, SO tight on the turnbuckles.
Is it just my kit, or is the body pathetically flimsy?
I was missing one of the 3 hole hub inserts, I got 1 3 hole, and 3 2 holes. Not major, but annoying.
My gearcover has a big melted hole in it, looks like a soldering iron touched it, but more likely wasn't molded properly.
All in all an OK build, hopefully they'll get the problems worked out. Going to email about the messed up parts tomorrow.
Also, I noticed some typos in the manual, usually parts being labled with the wrong color.
Can't wait to hit the track!
If you get the B5 kit from Lunsford, you won't have the turnbuckle too tight on the ballcup issue.
gticlay is offline
Old 03-07-2014, 07:25 AM
  #5425
Tech Legend
Wild Cherry's Avatar
Personally feel the new ball cups are the best ever, strong , tight & smooth...
A little need wax makes threading all the easier.
Build Tip
Don't use petroleum based products to lube the threads.
If you use grease the ball cup will thread on easier, but after a day or so the grease swells the plastic and the ball cup grips even tighter making adustments
almost impossible.
use wax or soap instead
Wild Cherry is offline
Old 03-07-2014, 08:04 AM
  #5426
Trader Rating: 65 (100%+)
The rod ends are not harder than any other car.
1. Clamp the turnbuckle in a pair of vise grips.
2. Take your Chapstick out of your pocket and stick the threads in it.
3. Push and turn the rod ends onto the turnbuckle.
It may take a few attempts but don't give up.
4. I actually used my shock shaft wrench from my ebuggy and it fit the outside of the rod end well enough to allow me to use it for leverage. It was one of the APE shock tools over on the tekno ebuggy forum.
Antimullet is offline
Old 03-07-2014, 08:21 AM
  #5427
Razathorn's Avatar
Bull. You surely have some nice tips, but to claim they're not harder than say the previous generation AE ball cups is completely ignoring mountains of empirical evidence and feedback. I built a b44 and a b5 in the same week and the difference was pronounced.
Wayne
Razathorn is offline
Old 03-07-2014, 08:23 AM
  #5428
I built some 30 kits in my lifetime all scales onroad offroad and I have had a set of mini vise grips for that exact reason. The other key instruction is the "push and turn" method, works everytime been doing it forever.
Great advice!!!!!
Bubonic-X is offline
Old 03-07-2014, 08:25 AM
  #5429
Wink
Wayne
I meant it figuratively Wayne. Like "Come on you can do it! It's not hard!"
I agree with you compared to the old gen cars. Definitely an inprovement!
Old 03-07-2014, 08:45 AM
  #5430
Razathorn's Avatar
Originally Posted by Wild Cherry
Don't use petroleum based products to live the threads.
almost impossible.
I don't think the AE black grease IS petroleum based -- pretty sure it's lithium based. That type of grease is specifically designed for applications with plastic. I have some ae black grease that's been in a plastic tube for 15 years and the plastic tube is just fine, plus they continue to ship it in a plastic tube.
Seems kinda backwards if it attacks plastic. I really doubt AE told us to use a grease on a part it would attack. We've been using the AE black grease on plastics since forever and I've never seen one thing swell from black grease.
Wayne
