Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#496
Mm already has taken over the Nw because all the indoor are med to med high traction.
Also the traction is only to grow stronger as the years go by.
This insures the mm will be the most popular in the area.
Outdoors with moon craters & dust bowls the rm will still be a better choice.
#497
Here is another part of the MM vs RM discussion, and that is track design. This track shown here is nothing but free flowing medium speed corners. Nothing in this layout really requires a lot of instant traction to the rear tires. All I saw were a couple of cars with their rear-ends sliding all over the place.
For example, here is a race at my local track recently... All mid-motor cars you will see. But we have probably 10x the traction. If you put the surface from your track, with our layout... mid motor cars wouldnt' be able to make it around the track. RM would dominate.
http://www.youtube.com/watch?v=kJc9qbQg73A
#498
The biggest difference with all these RC cars is that people are free to run whatever tire they wish and some cars will simply have a superior combination of rubber that will allow the car to go better, so people assume it's the configuration that's superior.
Certainly MM vehicles will have superior characteristics to that of RM vehicles and visa versa, but a well designed MM car should be faster than a RM simy because of balance and weight distribution. The current crop of MM cars however are not what I'd consider properly designed MM cars as they basically just flipped the drivetrain around to change the displacement of weight further forward. And while that's the ideal thing to do, the drive train should also maintain a neutral balance from side to side which NONE of these rig kits offer.
In the b5 I still see the motor offset a bit more to the left which is something I expected they'd change being as Centering kits made a significant improvement in that area.
Either way, whether MM or RM, a car that is set up well is set up well and nw I'll rip on any track provided you run the right tires and suspension setup.
#500
dup
#502
I imagine there will be a lot of Centro for sale now.
#503
On any given day I can walk into OC_RC and see many of the Reedy racers practicing for the race and 99% of them are MM. I was also told that many of the AE team drivers wont have a B5 by then, I don't know if that includes the "Ryan's" though, but I do know that Cav won last Sunday's club race with his Centro. Also to get further off the B5 rm discussion, the last time I saw Ryan Dunford and his 22SCT he was putting it in MM configuration.
#505
Some of you guys are so full of crap that I can't contain myself. The diffs in these cars are all basically made from the same parts. The 22 diffs suck and always will because of the materials. If you buy BFast parts for a Kyosho diff, an AE, and a TLR how could one be smoother than the other? Same parts. The design is basically the same! The only exception is that the diff with more balls theoretically should be smoother because there is more surface contact between the balls and plates and each ball [theoretically] has less psi of pressure being exerted on it. I'm not an engineer but this is not rocket science either. What I'm saying is that nobody's diff is better than anyone elses barring Durrango which is a little different...I only built a couple of those. Its been a while. I don't remember anything other than the weird cir clips and what happened if you put them in upside down. Anyway, a diff is pretty much a diff. If AE decides to step up the quality of the materials then there could be a substantial difference. More balls should be better as you should be able to get more clamping pressure on the diff rings.
On a side note, mid motored cars, pretty much all the Kyosho cars, have been doing well locally in all traction types. I'll probably convert everything to mid motor eventually.
#506
I agree the TLR forum support is the best in the business but do note that you have had two different AE design engineers answer questions about the cars on this thread and that seems perfectly adequate to me at this early stage.
I think manufacturers have to walk a fine line because because when you hear about all of the tinkering the pro drivers and engineers are doing with their cars to up the performance it can be perceived as addressing weaknesses in the car, rightly or wrongly.
Their seems to be alot more clarity when rep answer questions immediately the way Losi 22-4 thread is going. Less speculation. Still think T/A especially should read the two threads to understand. Its tough to decide one way or another till you actually see them. Incredible amounts of pre-orders being done for all companies. Great news for the hobby!
If the Losi 22-4 is competitive, its a big game changer. No more mm vs rm controversy. A huge simplification/win for all of us rcers. Other manufacturers will also switch.
Thats what I'm most interested in answering. A motor balanced within the chassis with the batteries at the back. Theory makes sense.
If it can win equally against mm and rm, this is a HUGE game changer design.
I'll hold off purchase decision for a month after its released to allow setup learning curve.
Make sense?
When is the next big pro race either here or in Europe?
#507
#508
The ball diff in the DEX210 uses 3mm balls, and uses 14 of them. It's the single best diff I have ever run (too bad about the rest of the car), and it's "tuning window" didn't feel any different. Actually.. i think it might of been slightly more forgiving. Im excited to hear that AE went with a 14 ball diff. I assume it will be 2.4mm ?
#509
Make sense?
Make sense?
The Reedy Race is January 23rd-26th @ OC_RC
