Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#4292
Anyone know when that pictured Reedy ESC will be available? I'm trying to decide whether to hold out on doing a Reedy ESC w/ Mach 2 17.5 or go Tekin RS Pro Gen 2 17.5. Thanks for your opinions!
#4294
I just sold my RB6. Ran it in mid motor and rear motor. Did very well with it. What would you like to know? Both are great cars. I think the only real big advantage the AE has on the RB6 right now is the adjustable front trailing axle -- that really makes RM on small tight tracks so much better. Other than that, I can't say anything extremely one way or another on either. The RB6 is nice that you can convert it, but damn, the b5 in RM is so super plush--up until driving my new b5, I would have always given the nod to kyosho on shocks, but the b5 is like a frigg'n cat, and I can't explain why, it just is.
Feel free to ask specifics.
Wayne
Wayne
#4296
I have the Kyosho now and I just can't get it to drive to my style of driving, it does not like to be ran aggresive it likes to push on power or even mid turn on all my different setup changes I either gain or lose one or the other. My current track has a lot of turns and the 22-b4.1-2 are just lot more constant and can power on through the corner as where I feel I have to baby it a littler more in the turn. Just curious I guess on how it drives can you be aggresive more with it compared to the rb6
#4297
There's a new video of Sean driving the b5m. Sorry don't know how to make link with my phone.
#4298
Wildcat, i am glad they didn't make it on the fly esc tuning, or that would make it illegal. As it is you can adjust parameters, but the receiver must be power cycled. I don't see it becoming roar legal because of that though.
Guy makes adjustment on remote, 3 laps in his car "stops" going, tells marshall to turn it off and back on, and vuala.
Unfortunately there are to many cheaters that will manipulate graet ideas, and turn them into bad ideas.
#4301
However, reading through the manual tuning tips they say the same about the 3mm trailing axle adjustment.....so now i'm curious as well.
I feel the 30* caster would have an effect on the suspension setting as well so maybe the trailing axle is a less drastic measure. Can anyone confirm?
#4302
George, you know when TRCR is getting more B5's in stock? I know Scott's in Hawaii atm, maybe Gene would know??
#4303
Wayne,
I was pretty close to what you posted here. Had brown in front with 30wt and black in rear with 25 wt with 1mm still on the steering rack. Started to go off the rails and added weight - knew I wanted to start over at that point. Yanked the weight and went over to your posted setup for a try. Was wondering if you had experimented with the .5 rear hub. I had it and the 30 degree kick up in and couldnt decide if it added more push than helped the rear end. Plan to be running it tonight at Kcrc.
#4304
I believe the 30* kick up is more for corner entry. My feeling was that car had more mid corner push and through sweepers.
#4305
