Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#3871
Also speaking of setup for those that are not following the B5Nation group on facebook, I have been dialing in a setup for outdoor/blue groove/high traction track.
Front:
3mm trailing axle
32.5 AE oil
Green spring
-1* camber
1* toe out
Rear:
30 weight AE oil
White spring
-1* camber
3.5* toe in
2* anti squat
2mm infront of hub
Orange barcodes all around.
I also have .25 FT ae stick on weight on the servo because I was under weight at our last race.
Front:
3mm trailing axle
32.5 AE oil
Green spring
-1* camber
1* toe out
Rear:
30 weight AE oil
White spring
-1* camber
3.5* toe in
2* anti squat
2mm infront of hub
#3872
I started building mine last night, really impressed with the front end and steering rack.. Only hickup I ran into was the rear shock tower, the 2 screws towards the rear were too long and ended up hitting the screws from below.. In the end I think I had the screws for the front skit plate suspension mount in the back and had the shorter ones (the right ones) in the front..
Does your guys cars have a lot of front to rear slop in the rear a arms? AE slop is good in my past experience though??
#3873
#3874
Changed some adjustments from what some people have said here and car is close to dialed. Still need a bit more rear traction now that the push is gone. Thinking dropping the kit setup shock weight will help.
#3876
http://www.lunsfordracing.com/mm5/me...egory_Code=NEW
#3877
I reamed the ends of the ballcups with a body reamer and that, combined with some grease on the threads have worked great for me. I can adjust with ease now.
#3878
I threaded off and on like 10 times & combined with chapstick, they adjust smooth as ever. Just takes some work.
#3880
#3881
Do we still pass that tidbit along?? The old 3 threads in 1 thread back when tapping new holes with screws?? Same thing for the ball cups, just always be aware when you're cutting new threads, back and forth, back and forth, side to side, back and forth.
http://youtu.be/WVvlVHdLCx0
#3883
Get these shorter ones Lunsford is selling for the B5
Ballcups thread on smooth and their classy look kills.
#3884
Super Moderator
Trader Rating: 31 (100%+)
#3885
