Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#2641
#2643
#2644
#2645
Sure wish they (Assoc) would source better diff rings, took a lot of sanding on the diamond plate to get them mostly flat. I ordered a fast pro kit and requested extra 2 balls to make it a B5 set instead of B4. Hope they read they're e-mails before they ship.
#2646
What I meant was I used my B4.2 chassis (rear motor) to "estimate" where the ESC and motor would be on a B5M and measured the length. I don't have anything longer than 100mm right now, which is why I need to get a new one.
#2647
Low-profile servo: Has anyone tried to install a LP servo standing up? Of course you would have to use another steering link.
#2650
Is there a space inside the top plate to mold weight into?
#2651
Is it possible the ring was warped? If the material is of uniform thickness and the out-drive plate is flat then under pressure it should even out. If you grind a warped ring flat, then it would become wavy (due to uneven thickness) once a perfectly flat backing surface were pressed against it.
#2653
