Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
B4 bumper works too and covers hinge pin cover
^^^ yes the stock AE B4 bumper works fine. If you want a little more coverage without being to much bigger the RPM B4 bumper covers a little more then the stock AE B4 does.
How would you use a ballcup i stopped using the screws and the locknut because it did put 2 small dents in my battery, now i just use the foam and the battery strap without the screw and the locknut.
Hey. Guys ,
To save me months of research , what is the proven best 17.5 spec motor on med to large out door tracks ?
Straight out of the box legal motors .....
Thx chad
Thx chad
Ya the locknuts are a bad design. I used two old ballcups and cut the ball part off with a dremel. Then used longer screws to get them nice and tight. Works great.
R/C Tech Elite Member
I used something like this with my Schelle Strap:
http://www.tqrcracing.com/shop/produ....asp?p_id=8209
You could use something longer, there are longer posts made by the same company.
This also works, and you could some fuel tubing around it to prevent dents in the battery:
http://www.exotekracing.com/alloy-posts-18mm-blue-2/
sub'd. Ignore.
I just heard about this on Friday and the guy who told me about it had a T4.2.....I probably got that wrong. I still haven't bothered to check, He actually had the ST bumper on his buggy and it did seem to cover the front better which is important for us because our outdoor track is very rough. When I say that I got it wrong I mean to say it's the T4.2 bumper that's wider.
The ball stud on my steering rack keeps backing out, would you recommend going with the aluminum or the plastic?
The aluminum one is fine but remember that if you're prone to hitting the pipe or wall that puts you one step closer to damaging your servo each time you hit something hard...the aluminun rack does not give. If you have the aluminum bell cranks already you really put your servo at risk as the 5 series cars don't have a servo saver. Add an aluminum horn and I guarantee that your servos will not last long....
Make sure the steering link is not binding, verify it swivels freely on the ball studs. Give them a squeeze if not. Same as you would for the turnbuckles. Replace the plastic steering bellcrank if the hole is wallowed out. Use Loctite on the ballstud threads if using the aluminum bellcrank.
