Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
So the search function on the phone site sucks.
I am contemplating switching from my certified kill shot to one of the D4 1s 17.5 motors. Would it be worth the switch and what kind of timing gearing do people run with the 1s short stack motors
Thanks in advance
Thanks in advance
Your car is fairly light for a mod car. What surface are you on? What is your setup? What tires?
What pinion and spur?
What timing?
There are so many variables, you have barely scratched the surface. And let me also mention, there is NO way a B4 is weighing anywhere near 1525, I don't have a lot of experience with that generation of cars, but I do know they are SUPER light, lighter than even the B5 rear motor.
You're running very hot for a mod motor, I would try dropping a tooth and seeing what it does. How old is that motor? What was the last time the rotor was zapped? Weak rotors will make a motor run hot regardless of gearing or timing.
What timing?
Running on hard pack dry dirt, dusty and loose on top. Soft Blockades on the back and soft 3 ribs on the front.
I did get the motor used, speed passion 8.5R, so don't know it's history. Never heard of zapping the rotor.
The motor has a 10* adjustment window and is set in the middle. Esc timing is set to 17* the way it came out of the box.
As for the B4 I haven't actually weighed it myself but trusted what I was told. If I get a chance I'll weigh it myself with the same scale to confirm. I know the B4 runs full size packs so they might have added to its weight.
I do have a Tekin motor to try and am now wondering if there could be a big difference from a Tekin esc(RS) to the Hobbyking(Hobbywing clone) in its power delivery to the motor.
I was using trim. But what is the difference?
Also, anybody know why my steering turnbuckles have to be different length to achieve the same toe on each side? One turnbuckle has to be 25mm and one has to be 28.5mm. Steering seems to be at center.
Battery configurations for B5 rear
Hi Guys
Looking for feed back on the following modification to the B5 rear motor chassis. The photos speak for themselves, but interested to know what you think
81T spur and 20T pinion
Go to a 78 spur, and try a 24 tooth pinion and then change from there based on feel and temp. I don't see a reason to run an 81 tooth spur.
B5 battery configurations..........
More photos from previous post.............
Looking for some help. I am running 69/32 on a high bite indoor carpet track. My 17.5 reedy motor is coming off around 110 degrees with the timing at about 37 degrees. I would like to be able to get some more power on the low end to clear some triples. Right now I can clear the triples through the first half of my pack but not the second.
Can I do anything with gearing to help?
I think it will push like a train, the b5 already has plenty of rear weight bias it doesn't need more. Where would you mount the esc with a stick pack?
Already running the slipper eliminator and the 3 gear. Just tried a new orion 4500 100c lipo also as i thought my Reedy 4100 was weak.
X2, I started running outdoors on a loose track and going to 78/24 or even 25 was a huge improvement overall. The car had better grip and more controllable out of turns. For me it really cut down on wheel spin and pushes the weight further back over the wheels.
Using trim to center your steering is like holding the steering wheel off center to go straight. Now lets say you have to hold it say 45 degrees to the left to go straight. If your wheel can only go 90 degrees to the left total, you can only turn another 45 degrees and that's as far as your left turn will go.
By using sub trim, you move the center point on your steering, and the end points also shift with it. You now have a new center point for your steering, giving you a full 90 degrees off center in this case for right and left turns.
What ESC are you running?
Turn the timing up on the motor, first off. I have ZERO experience with the Reedy motor, however most run them around 45-35 degrees.
What is the IR on your battery? What weight is the car?
I was running about 42 deg of timing on my reedy 17.5. But 110 deg....that is really low heat for that gearing.
Like Socket said, what does your car weight. The more weight you have to lug around the track, the more drain on your packs. And less "pop"
Anyone know if the Schelle slipper setup is lighter than the older V2 - 2 pad setup?
