Team Associated RC10 B5m Mid-Motor Thread
Super Moderator
I can't really be sure which is a direct replacement for the B5R kit hexes(never had one, I only just won a B5mFL during the summer, & it's my first Associated since the B4), but I know that my car came with the 91610 hexes, so I should think those would work fine for you.....
Hey guys,
I want to upgrade the rear hexes of my B5r. Didn't do any changes on the kit, all box stock.
I did a little search on this thread and I'm a bit confused - which clamping rear hexes do I need for my B5r for a direct replace with the kit plastic hexes without changing the width of the rear axle?
Would it be
#91442 or
#91610 ?
Or any other part# I didn't find?
Appreciate your help
Would it be
#91442 or
#91610 ?
EDIT: Checked again and it does only list the #91442... Guess I looked wrong last time. Sorry!
But I guess since _danimal_s answer it must be the normal ones.
Will be ordered.
My B5M gear diff is leaking.
Is there any trick to avoid leaks ?
Depends on where it leaks...
First, don't fill it too much
Black (or green) grease on gasket and o ring
Tight the 4 screws in a cross move
How do you measure front toe?
Buy expensive set up gauges specifically for off road car, eyeball it and not worry, two paint stir sticks against the front wheels?
Any suggestions?
Any suggestions?
Park the nose of your car against a wall and use the camber gauge to measure the toe by placing the gauge on the wall instead of the ground. Turn the car on so the wheels stay in the same place while you measure.
Also what's important is that changes you make in certain areas can effect other settings. You can see all settings at once on the setup station.
If you're going to go so far as buy measuring tools, you may as well buy set up wheels too. Off road tires are far from true and gluing them up makes things worse. Spin them once and set Your toe, spin them again and everything looks out of whack. That goes for camber and toe.
