Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
I dont think it was "big air" that would have been nice, just a more flowing, faster track that isn't catered to just 17.5, which the new lay out still is for the most part. The triple is not that hard to make, but it literally turns in mid air so the margin for error is incredibly small. Wish they would have made it a straight jump.
I was doing it with my wheeler. lol, in fact that section was much easier with my wheeler. It ate my lunch in stock. Plus people crash in there. And if you get caught behind a pile up, your screwed. Try to dodge cars you cant see and marshals is fail. I had a good run last weekend, then lap traffic in that section ended an otherwise good run.
R/C Tech Elite Member
Guess you need a new body for the 3 gear since you have to chop off the other side...
At our track we run a 13.5 class with carpet tires (ie. Proline pin points/wedges) on Ozite carpet resulting in very high grip. We have very small jumps. Thinking the 3 gear might be worth a shot. Any thoughts?
Super Moderator
Trader Rating: 31 (100%+)
You NEED the the top shaft, tranny case, and gear cover. The stock motor plate can be used. You just need to mount it with button head screws vs. the counter sunk ones and shim the spur gear out a little bit. Motor plate should be out soon, if not already.
body...looks more uniform when you have both sides cut out
I run stock about 3 times a year, so I'm not in a big hurry to try it. Even though I have a dedicated B5m just for stock now
My thoughts, spend about 15 bucks and try it.
Super Moderator
I personally don't like the idea of both sides of the screw holes being counter sunk, not enough material left for a solid mount. That's just me..I actually crash unlike the rest of RCTech
will there a kit to trun the b5 m in to a truck?
They, button heads, will. Which is why I said, in the post you quoted, to shim the spur out a little bit.
I picked up a CF motor plate from Plan B racing. And no, not to save weight, but it is light. Yes, I am aware that CF does not dissipate heat like aluminum. No I didnt get it because it was pretty. I picked it up because it was available, it wont tweak, it was only $15 shipped and perhaps less flex to keep a better mesh.
Super Moderator
Sell your B5M and buy a T5M if a ST is what you really want.
I did per order a 5 t but I got a yeti xl kit now ill get one for my birth day in may
Super Moderator
hmm, selective reading I guess
On a side note. I'm glad I'm not stock racing very much, locally or otherwise. Because I found out first hand that the whole battery "juicing" game is no joke, legal or not it makes a difference.
