Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Rear bite is what I felt. I love how the mm flys though.
moving to 17.5 need some advice
So I just got the x-factory chassis,mip alum topshaft,mip pucks and a Team Scream 17.5.should I run the inline setup......and what do you guys think I should start at for gearing??????thanks for the input.
And schelle slipper eliminates a good amount of rotating mass. Something to look in to before buying your gears.
I'm could agree with tire spin. Because sometimes the MM car would break traction and regain in one instant on the two 180 corners our layout has.
More drive time will reveal what I need...either mental or actual setup. LoL
Checking into see what is the preferred orientation for the aluminum rear ball stud mount. +2m or -2mm?
Building mostly to a Cav setup sheet which says (Low +3mm) of which I'm not fully understanding.
That means go with the -2mm orientation on the mount, but with 3mm of washers on the ballstud.
Low +3mm means flipped upside down -2mm +3mm equals +1mm on stock brace
R/C Tech Elite Member
Then add 3mm of shims under the ball stud.
You could go +2mm and only put 1mm under the ball stud. both would be the same height.
I want that mip 3 gear. It looks stellar. Am I correct in assuming that it weighs more than the ae 3 gear? I want a ill more weight back there.
