Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Yes
Suspended
Carbon rear shocktower.
NOT FOR SELL!!!!!
Jerzi
NOT FOR SELL!!!!!
Jerzi
thanks. im running on a med bite loose hard packed indoor track. im running it box setup and cant get steering or bite the car just wants to spin out i have to feather it the whole race and have on power steering. im putting flat arms on it now. is there anything else i can do or buy to improve these issues? please help thanks
What's a good servo to run in the buggy
Saw one in last night. It came out before the main.
putting b5 arms on flat front and back. are the shocks suppose to mount to the front of the arms instead of the back like the stock ones? the rear arms look the same
I need some help on building the shocks on the B5M. The manual says to use a 5mm shock cup but I only see shock cups marked 1,2,3&4. I cant figure out what shock cups I should be using in the front and rear for a track such as OCRC in HB. Any help would be great.
My thoughts exactly... Make sure you have the correct tires and make sure your braking endpoint is set right... Touchy brakes can throw off your throttle if you are on and off both all the time... Mm is alot different then rm... For me i had to adjust to being alot more smoother at first... Really i dont even use the brakes except when jumping... You always have to be on slight throttle through the turns cause if you let off suddenly sometimes mm buggies will react violently... its all about how smooth you are with the throttle IMO... Box setup should run fairly fine with the correct tires!!
R/C Tech Elite Member
As far as proper building, theres a great youtube video out!
https://www.youtube.com/watch?v=k2ahQOYp49Q
https://www.youtube.com/watch?v=K5CLUAJIWIQ
https://www.youtube.com/watch?v=DCEtEPH526c
