Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
I agree with the above Ti turnbuckles are about the only out of the box upgrade you need. The rest of the car is really good, on both my B5 and B5m i have broke one front shock tower and one front bulkhead. I have had both cars sense they came out.
And if you want to be extra cautious (I never bother with this), you can use a LONG ballstud that sticks out below the camber mount and pop a small nut on it.
*Deleted, problem solved.
I've tried to install the brass arm c mount (91523) and cannot for the life of me work out how it comes together with the rear tower on the rear of the chassis. What am I missing?
Can one of you fine gents post a picture or explain what I need to do please?
C goes forward. Not near the tower
I've got pucks and cb's cut gears and everything installed with no issues...
Ha ha priceless!
it looks like I have bump out when I compress my front end. should I not worry about it or could I lower my front axle by 1mm or cut it down where the ball end attaches to go -1 on bump steer
Yes a lot of guys are doing cutting down where the ballstud goes since Cav put -1 bump steer on his setup sheet
the cav way seems like the worst way. lowering the axle or raising the steering rack to me could give the same effect without weakening the steering block. has any pics been posted of this mod
Moving the axle will change the geometry in other, unwanted, ways. Like ride height when the arms are level.
The ball diff will always be more consistent, provided it's broken in and tight enough (not barking). As a gear diff is used, the diff oil heats up and becomes thinner.
Cav's 2014 top gun setup with one thin pad in rear. The car was so good compared to what it had been, that I really didn't feel like I could change anything. I didn't know what to do with myself. It was just so good compared to what it had been that I felt like changing anything was just dumb. I'll have to see how it does racing.
I was running M4 electrons all around with the stock closed cell foams.
Yes you will notice more rear traction bc the arms push your rear hubs forward about 2mm from stock. Also you want to flip them and run the right one on the left side and vise versa
