Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Hello anyone reading this, just built my buggy this week, first 2wd buggy, I am stock set up and ran the first time on an indoor high bite clay track, ran pretty good, I have 2 questions for now, my slipper does not seem to function well, when i run the nut flush with shaft, diff barks, loosen it 1 turn out still not slipping, so I tore in down last night, diff and slipper, cleaned diff and lubed, seems to turn smooth with resistance, slipper has no signs of wear at all, put it back together and same thing, I have to back the nut off so loose i can turn by hand and then it slips any tighter diff bark? Second the rear end seems to slide out letting off throttle as long as i feather it seems more consistant, almost feels like high drag brake but I have none, is this a diff problem causing these problems? Ok a 3rd question since I'm here I changed my shock oil also, same weight, used same stock procedure, when i checked my ride height 24mm I had to crank the collars down about 8 turns compared to when I built it to get it right, shocks are smooth, no air that i see or fell whats up confused?
the bark is cause your diff is slipping, so once you get your diff tight you can tighting your slipper clockwise and then hold both rear wheels and the slipper and blip the throttle it should not bark and the wheels should come off the ground, if it doesnt come up tighten the slipper untill its popping the wheels off the ground a couple inches
How important is it to upgrade the shock stand offs? Seems to be lots of play within the shock cap on the stand off.
Had upgraded Schelle aluminum stand offs but a nut backed out. Ended up going to the stock to the front end....felt fine.
your diff is to loose, dont worry about the slipper slipping at all, you want to properly break it in. look up on youtube "ball diffn breakin"
That is exactly what i did broke it in drill method and table top one wheel at a time a couple of mins each side, tighening each time a bit until I reach 1/2 turn lazy spin on the wheel t-nut flush like in manual right now i have it at fully compressed backed off 1/8 turn, wheels come off the ground fine but slipper is far from the nut flush starting point
Super Moderator
Trader Rating: 31 (100%+)
Just not a method I would suggest to someone new to building ball diffs.
If it works for some of you, great. I personally don't get it.
I've never understood how people set their diffs with the "flick" method as some have called it How do you even know how hard to spin the tire? Is there some high tech calibrating process you use on your hand before giving her a spin.. I've tried "flicking" on my cars with diffs set where I want them and just seem to get widely varying, inconsistent results on the whole "1/2 turn of the tire".
Slipper is installed fine everything seated in its place, but i did not compress The spring so i"lll try that thanks, i compressed it on the diff though
It's not that big of a deal and the "slop" isn't anything to worry about. If it has excessive up and down slop a new set of plastic bushings is extremely cheap.
R/C Tech Elite Member
For reference:
http://www.rccaraction.com/blog/2011...ed-tebo-video/
http://www.rccaraction.com/blog/2011...yan-cavalieri/
Thanks a lot Cridd compressing the spring did the trick, i really felt the spring break in, sometimes the simplest solutions are overlooked, love driving this buggy now if i can get the rear from kicking out off throttle and gunning it. I got plenty or sterring, no push just some more rear bite needed,Its not missing much to get it dialed out of the box on our track
If we are paying to the difference between a 1mm spacer vs a 2mm spacer....the slop or free range of motion the shock caps have on the stand off bushings has to significant.
I used the Schelle Stand offs and the shock caps did not move at all.
With the Composite Shock Caps or or V2 Shock Caps on the composite stock stand offs we have lots of movement. AE doesn't even offer a hop up for that. That may mean its OK. Just hard to accept the slop when we always tune for no slop.
Guys, I need some help figuring out my buggy. It has been very frustrating at the end of last season and so far this season. It seems the rear never settles down and whenever I get on power it is very loose. The worst part is when I am turning. When I apply the throttle at the apex, the rear breaks loose and I spin.
I have tried different motors and esc's, tried different setups using the mid motor arms/front tower and the rear motor arms/front tower and have taken the whole car apart and rebuilt the thing. I didn't find any bent hinge pins or shock shafts. I have rebuilt the diff, changed the bearings and nothing seems to be helping. I even used my friends set of tires that were hooking up for him and it was slightly better. I'm not sure where to go from here. I am currently using this setup:
http://www.teamassociated.com/pdf/ca...sJumps_Gay.pdf
It's funny when I first built the kit it was great. I don't know what heppened, but this has been frustrating!
If still needing more after that. Try a stiffer frt spring and smaller spur gear to move the motor farther rearward. Run a sqaure or saddle pack if running mod. Research the oring mods for the rear waterfall.
Gearing selection
I'm running my B5M in both stock and mod classes depending on what track I'm at. Kind of struggling with finding the right gearing for both classes. Been doing a lot of reading today and studying a gear ration chart, which brings me to my question. If for example a 81/36 and a 72/32 will both give you a fdr of 5.85, what determines the combination you go with? What would the difference be running each combination on the same motor?
