How to change the timing on a speedpasion 3.0 8.5 motor ? >
Old 12-21-2013, 11:23 AM
Default How to change the timing on a speedpasion 3.0 8.5 motor ?
Can any one tell me how to adjust the motor timing on a Speedpasion 3.0 comp 3.0 8.5 turn motor ??
FLAT OUT is offline
Old 12-21-2013, 12:08 PM
zeakemedia's Avatar
Trader Rating: 95 (99%+)
You have to buy separate timing boards.
zeakemedia is offline
Old 12-21-2013, 01:50 PM
You can adjust it some by loosening the endbell and turning the sensor board in the slot. It can move something like 10 in the slot. Have to loosen it a fair bit due to the seals they use. More than that requires a different sensor board as mentioned.
Dave H is offline
