any help on a motor setup?
what is a good brushless setup for my lcg slash 4x4? brand, kv, gearing?
also thats fast with 2cell lipos 7.4v. thanks.
Most people I know run a tekin rx8. I think they have 4300kv now, I use the older 4600kv.
Tekin rx8 gen2 with a pro4 HD 4300, for make sure you have enough power,if you are on a budget you can consider hobbywing motor/esc.
Hobbywing Combo is GREAT!
Great performance and great price!
http://www.falconsekido.com/products...sct-pro-series
If you go with the Pro-C2 Combo it comes with the SCT ESC and 4000KV 4 Pole motor!
ESC Link:
http://www.falconsekido.com/products...t-pro-esc-blue
4000KV 4 Pole Motor Link:
http://www.falconsekido.com/products/xrm3656sd
Good Luck!
ESC Link:
Good Luck!
Well since its a slash, the Pro HD4300 I think would be over kill and too much power for a Slash 4x4
I would recommend using the Hobbywing SCTPro 120A and the Hobbywing 4000 4pole motor in the Slash 4x4. You can get the ESC for $85-$90 and the motor is $85
As for Lipos I would say atleast run a min. of 40C and 5000mah. The Slash is a little lighter then some of the 4x4 SCT's out there
dont want to spend that much for tekin stuff, whats the next best setup for a good price?
Hobbywing SCTPro 120A & Hobbywing 4pole 4000, best bang for the buck and has tons of power.
http://www.falconsekido.com/products...t-pro-esc-blue $90 for ESC
http://www.falconsekido.com/products/xrm3656sd $85 for motor
Lipos
$35 G-Force 2s 50c 6000 more then plenty for a Slash 4x4
http://www.valuehobby.com/power-syst...000mah-2s.html
Thanks, I will most likely get the hobbywing setup. What a good gearing setup? Pinion and spur
Hmmm I think Slash Spurs are 52, 53 & 54
I would say start with 13T Pinion and 54T Spur.
You should probably have a couple pinions on hand, I believe Novak and couple others make or sell sets, that come with 3 pinion gears.
On the pinions make sure you get the right ones that fit motor shaft and the spur gear
I believe that the Slash 4x4 is a 32Pitch and the motor shaft on the HW is 5mm
Okay thanks, 1 more question, the motor 4700 or 4000 be better
Best setup ever for the money, and competes with $300 tekins. It's the tenshock sc411 ( or sc401 sensorlesss version ) with the hobbywing xerun sct pro. Its on funshobby.com for like 130!
