Need imediate help! Ordering batteries. >
Old 12-17-2013, 06:49 PM
Cwarta's Avatar
Default Need imediate help! Ordering batteries.
IM orderdering batteries for my revo conversion.
My question is, if I run 2, 2cell batterys with a 5000mah rating each, does that equal 10,000 mah combined to make them 4cell total?
If it does, than say a single 4 cell battery with a rating of 5,000mah will have half the runtime correct?
Cwarta is offline
Old 12-17-2013, 06:51 PM
3D-Seth's Avatar
Trader Rating: 23 (100%+)
You can either run 2 2s 5000mAh packs in series or parallel (or individually of course)
Individually, you get the obvious - 2s 5000mAh
Run them in series, you get 4s (14.8V) 5000mAh
Run them in parallel, you get 2s (7.4V) 10,000mAh
Seth
3D-Seth is offline
Old 12-17-2013, 06:55 PM
Cwarta's Avatar
Seth
so with that being said, all thing equal 2 2s packs ran together is the same capacity etc as a single 4s if they have the same MAH rating?
Cwarta is offline
egobrkr's Avatar
Trader Rating: 29 (100%+)
If this is a erevo then 2 2s 5000mah would be 4s 500mah. The erevo uses them in seires which makes 2 2s into 4s. If it was in parallel then 2 2s 5000mah would be 2s 10,000mah. Parallel= double run time seires=double voltage.
egobrkr is offline
Old 12-17-2013, 06:56 PM
egobrkr's Avatar
yes
egobrkr is offline
Old 12-17-2013, 06:58 PM
Cwarta's Avatar
Im running them in a revo I converted to brushless. Both setups need to equal 4s.
so to be clear
X2 2cell 5000MAH packs is = to 1 4S 5000MAH pack
Cwarta is offline
Old 12-17-2013, 07:04 PM
egobrkr's Avatar
so to be clear
In series yes
egobrkr is offline
Old 12-17-2013, 07:27 PM
3D-Seth's Avatar
See attached
Attached Thumbnails Need imediate help! Ordering batteries.-batterywiring.jpg
3D-Seth is offline
