Turning problems
Old 12-15-2013, 11:32 PM
  #16
silvalis's Avatar
Trader Rating: 29 (100%+)
if you're running on pavement only theres no reason you cant use swaybars. Heck, anything high grip/bite i'd probably run swaybars.
Drop your rideheight (you dont need it for pavement), increase your rear spring stiffness, thicken your shock fluid, add a bit of weight on the nose if you need more steering.
silvalis is offline
Old 12-16-2013, 03:47 AM
  #17
Thanks guys. Yeah, I wouldn't think there'd be much weight to transfer...lol.
WannaBeSTi is offline
Old 12-16-2013, 02:23 PM
  #18
ThePanda's Avatar
Trader Rating: 68 (100%+)
to drop ride height, add a mm or two of spacers under the shock piston.
ThePanda is offline
Old 12-16-2013, 06:01 PM
  #19
There is weight there to transfer your running higher traction tires so its lifting your front end off the ground basically your trying to turn a dragster at the beginning of its hole shot for lack of a better explanation
scorpion51503 is offline
Old 12-16-2013, 06:50 PM
  #20
Good idea, i was actually trying to make it a higher ride height for the terrain behind my house, but i might drop it to play on the street this weekend!
iclrag is offline
