Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 02-20-2014, 06:38 AM
  #766
jkirkwood's Avatar
Originally Posted by mxracer71 View Post
i have some leaky shocks, i know serpent updated theres and i know xrings will fit also,anyone try the 22 or ae seals? i have some on order but in case we get in a bind and was curious if the others will work as well.
As Chris said you might try a .5 mm shim or maybe a bit less. I actually used just a .3 mm to take out a bit of weeping from my shocks. Be careful not not go too much with the shims as you'll bind the seal pack and have a worst performing shock.
jkirkwood is offline
Old 02-20-2014, 07:05 AM
  #767
I need some help. I have been running the mm for 2 weeks now and for the life of me I can not get a setup to work good. I run on Crc race carpet with wooden jumps. Track is 65*45 pretty fast as we run 10.5 and 8.5. I previously ran a Durango and had that car dialed. I have tried stock setup and pretty much everything I can think of but no luck. The car either pushes and have no on power steering or it turns on a dime and traction rolls. If anyone has a setup sheet for carpet it would be great.
chad508 is offline
Old 02-20-2014, 12:06 PM
  #768
Adam C's Avatar
We race on carpet during the winter over here in the UK (prima felt GT at my local club) the track is about 30 x 16 metres and has some small wooden ramps dotted around. Only raced my MM for 3 nights so far but initial impressions are very good, built well and no hop ups needed. Setup wise the pink springs that come with the car were way too stiff for the track I race at, and I was struggling for mid corner speed.
At the moment my setup is kit apart from: Schumacher Yellow Mini Pins Rear, Schumacher yellow low profile cut staggers on the front. Orange Serpent springs all round and an extra 5 degrees of castor on the hub. I run a 8.5t motor with reasonably heavy saddle pack lipos, car weighed 1620g but I’m thinking about adding 20g to the front.
The car was dialled on Saturday when we had one of our bigger meetings and really easy to drive consistently. Compared to other 2wd’s at my club my car is still reasonably stiff despite the orange springs all round but I don’t really want to soften it any more.
Hope this is of some help
Adam C is offline
Old 02-20-2014, 01:14 PM
  #769
DanielC.'s Avatar
Trader Rating: 56 (100%+)
Some new paint for the Serpent buggies
DanielC. is offline
Old 02-20-2014, 01:24 PM
  #770
FastPete's Avatar
Trader Rating: 44 (100%+)
Very nice!
FastPete is offline
Old 02-20-2014, 01:26 PM
  #771
elex300's Avatar
Trader Rating: 106 (100%+)
Wow! Who did the awesome paint work?
elex300 is offline
Old 02-20-2014, 02:55 PM
  #772
DanielC.'s Avatar
The same person who provided the image hosting
DanielC. is offline
Old 02-20-2014, 07:39 PM
  #773
Ok guys just built my mm serpent. Now I know in the book its doesnt say to put any grease or anything in the transmission gears. Would it be beneficial to do that or not?
rrussell is offline
Old 02-20-2014, 07:53 PM
  #774
elex300's Avatar
Its not necessary. Some people put a few drops of like 20k diff fluid on the diff gear to quiet the transmission. I prefer the gears to be dry so they dont collect dust.
elex300 is offline
Old 02-20-2014, 08:58 PM
  #775
Kellen Guthrie's Avatar
Is anyone running serpent springs on med to high bite clay? I never really gave them a chance since I didnt like how low the coil count was. After seeing how much grip the car manufactures i was thinking of trying them. Any suggestions on extra springs to pick up besides the kit ones?
Kellen Guthrie is offline
Old 02-20-2014, 10:08 PM
  #776
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Post your setup. What tires/inserts are you running? Is the carpet Ozite?
RMKinWI is offline
Old 02-20-2014, 10:49 PM
  #777
opsman's Avatar
I ran carpet last week for first time with MM, just normal cheap carpet.
tyres were Dboots nanobytes rear and Schumacher blocks front
Shock oil std
front brass bulkhead
springs on front purple
rear AE grey springs (lower ride height ability)
Shock tower position front 4th hole in
Shock bottom front outside
rear tower and shock std
All depends on carpet grip to start with and what tyres you are using but this was good for me I came 4th in A-Finals
I will play around a bit more next time but this was a good start, I had help from jkirkwood here on RCTech :-) and changed from there
opsman is offline
Old 02-21-2014, 07:01 AM
  #778
FastPete's Avatar
All I heard is blues on the back.
FastPete is offline
Old 02-21-2014, 07:06 AM
  #779
Trader Rating: 19 (100%+)
We definitely like the Blue rear spring, haven't felt a need to go any firmer or softer on the front spring yet. Our track is high bite, and even when traction drops off it has more bite than almost anywhere I've been.
Jonny5 is offline
  #780
I tried ae they are od is wrong. Kyosho clear xrings and green slime. Zero leakage. Mine are close to six weeks.
sobiski racer is offline
