Serpent Spyder SRX-2 Mid Motor Buggy Thread
#752
Just checked ABC wiring and everything matches. I replaced sensor cable and still the same results. It's weird because reverse works perfectly fine, but going forward it will make a ratcheting/screeching sound or not move when placed on the floor like on the video. With no load/wheels in the air, it spins.
Because of all the troubleshooting trying to sort out my diff, my diff is a little gritty and I also glazed my slipper pads. What a day, never had this many headaches with brand new parts.
#753
Well after stripping an idler gear in my Serpent last Wednesday I had to resort back to my 22 2.0. It was very depressing. I went from easily being top 5 in mod buggy with my serpent to missing the bump in the B main with my 22 2.0 on Friday. Somehow I managed to pull off a win Saturday with some smart driving and low grip conditions (switched to RM). Can't wait to run the Serpent again this weekend and make the AE drivers cry.
#754
Sorry for the lack of updates, real life(work) took over for now, but i did manage to find one cause of my problems: One half stripped idler gear due to forgetting to install an insert on one side of the gearbox.
#756
#757
brain fart number 2.
I wonder if my motor is still bad due to that weird high pitched sound under load and a perfectly fine reverse. Unfortunately, my spare parts are in bound and arriving Friday so I'm stuck waiting to drive this buggy for the first time. Plus my ball diff is gritty now and waiting for more B Fast carbide balls with Avid carbide thrust bearing(instead of the ceramic Casper thrusts) for a slightly easier and more forgiving tuning window.
#760
i have some leaky shocks, i know serpent updated theres and i know xrings will fit also,anyone try the 22 or ae seals? i have some on order but in case we get in a bind and was curious if the others will work as well.
#761
One other note I have is I was having a problem with my top nut coming loose on the shock shaft, and I was using lock tight, which probably also contributed to my weeping shocks. I sanded down the washer that goes under the piston, which added enough thread to resolve the problem.
Chris
#762
#764
Have my kit, middle of a move though and don't have my R/C space setup yet at the new house.
Driving me crazy! the only thing worse than waiting for a new kit to arrive, is staring at it unable to build it lol!
Maybe by next weekend i will have it done, and hopefully i can find some Clay typos by then as well! Been backordered for a month lol.
#765
