Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 01-24-2014, 10:15 PM
  #286
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by DanielC. View Post
Maiden run in the books! Ran well, but not a huge fan of the stock shock setup for my track. Feels over dampened. Gonna try a more traditional oil/piston combo next time
Great, do you have a RM also? Curious how you thought it handled compared to the RM if you have one.
FastPete is offline
Old 01-24-2014, 10:26 PM
  #287
DanielC.'s Avatar
Trader Rating: 56 (100%+)
I'd say the rear motor is definitely more dialed in from the box. It handles similar to the RM with more corner speed and less forward bite. Makes sense since it's the same front end. Lighter shock package will be the ticket and maybe some tweaks to the Ackerman. It felt very balanced though, and it was predictable getting on power mid corner/exit. Steering just felt a little numb because of the aforementioned damping
DanielC. is offline
Old 01-24-2014, 10:31 PM
  #288
Kellen Guthrie's Avatar
Originally Posted by FastPete View Post
I see white rod ends.
They are a light grey. They are updated rod ends that they were testing. I think that they came in the new MM kit but don't quote me on that.
Kellen Guthrie is offline
Old 01-24-2014, 10:33 PM
  #289
FastPete's Avatar
Don't look like it in Daniels pics, was just curious.
FastPete is offline
Old 01-24-2014, 10:39 PM
  #290
DanielC.'s Avatar
Mine are a matte finish unlike the glossy ones from my other car. Lawn darted a couple times in practice with no issue. Transmission case is going to be updated btw.
DanielC. is offline
Old 01-24-2014, 11:49 PM
  #291
Crawlin's Avatar
Trader Rating: 22 (100%+)
Maiden voyage tonight as well. Needs some work but i love this car. Some little minor issues, but nothing that couldn't be overcome during the build.
Played around with Truhe's setup he is running at the Reedy race. A little higher bite out there compared to here. Its going to be a VERY competitive car, that's for sure.
I have the RM as well, and while I think each has their benefits and places they'd work best at, I'm very happy with it on our medium bite hard packed dirt track
+ YouTube Video
Crawlin is offline
Old 01-25-2014, 12:04 AM
  #292
I'm having trouble with the servo horn binding on the top plate. Running a GM low profile servo. Anyone else had that issue with there servos?
johnboy282012 is offline
Old 01-25-2014, 12:12 AM
  #293
Trader Rating: 19 (100%+)
You probably need to add another shim or two between the servo and the servo mounts to space the servo forward some more. And make sure your servo is flush against the bottom of the chassis as well.
Jonny5 is offline
Old 01-25-2014, 12:18 AM
  #294
The servo is a low as can get it. Will add more shims have number 2 and number 3 in will try adding number 4 see what that does
Old 01-25-2014, 05:35 AM
  #295
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
+ YouTube Video
Where can we see Truhe's setup sheet?
BOLISARIO is offline
Old 01-25-2014, 06:41 AM
  #296
Crawlin's Avatar
Setup is on petitrc
It is really high bite out there so its an ok starting point forsome tracks. But I think you'll find yourself moving away from it with some small adjustments.
Personally, I took 2mm out of the rear inner camber links and the rear felt alot more locked in. I tried a red front spring and it helped some low-mid speed cornering but we have a huge sweeper right after the straight, which is right after a wall ride so we have some huge speed going into it. The front would roll over with that red spring and hook hard and cause it to get a bit loose. But it was unpredictable. With the pink spring up front I will need to play with some other changes to get the low-mid corner steering I need. More than likely play with the ackerman since I played with it on my RM car and REALLY liked how the #3 worked.
I also played with shorty all the way back vs. saddle. I remembered I had a saddle laying in my bad from my wheeler so charged it up for the main and the car felt alot better. Harder to explain but it just felt more "balanced".
I'm still running the AKA Typos in clay so maybe the setup would work better with a bar style tire
Crawlin is offline
Old 01-25-2014, 07:07 AM
  #297
Quick one what recommend a pinion running 7.5lrp x20 and standard spur 78t was thinking a 21t
Old 01-25-2014, 07:42 AM
  #298
Crawlin's Avatar
On my track I'm at a 19t with the 78t and still at 70% on the EPA and its a rocket. I run an ORCA TX 7.5
we are a med size indoor track
Crawlin is offline
Old 01-25-2014, 10:17 AM
  #299
BOLISARIO's Avatar
Setup is on petitrc
Thanks.
Looks like I'll have to buy some saddles now since it provides a better balanced ride. I was hoping I can get away with using the shorty packs I already have.
Old 01-25-2014, 11:44 AM
  #300
Anyone else have a clay/mud like substance in their outdrives? Easy to clean but seems a little strange to me.
Wish the battery compartment allowed the shorties to run along the car instead of parallel. Wonder if I could just cut out that blocking section.
shagino is offline
