Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 01-23-2014, 01:34 PM
  #241
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by DanielC. View Post
Long night ahead!
Enjoy pics now!
FastPete is offline
Old 01-23-2014, 01:40 PM
  #242
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Originally Posted by Crawlin View Post
Yes, I cut down the proline rear inserts(had a bunch leftover from my Ions I use to run. But it is cut down more than the 1/4" I would usually cut off for a barcode. When I cut it down normal it just seemed stiffer than the stock inserts. and the tire profile didn't seem right. Cut down until I felt comfortable with the profile and works fine.
And yes, the front wheels need to dremel down the face of the hex area. Essentially the hex portion rubs on the hub. You need to shave it down to where it is even with the "ribs" of the inner wheel
http://www.petitrc.com/setup/serpent...VOFrontWheels/
Takes all of 5 minutes on both wheels at the most.
Thanks for the tip. I wonder if we can get the OP to add stickies re: build tips, mods, etc.
Long night ahead!
I'm jelly too.
BOLISARIO is offline
Old 01-23-2014, 01:47 PM
  #243
F!*%. Shoulda ponied up for overnight
shagino is offline
Old 01-23-2014, 02:00 PM
  #244
FastPete's Avatar
Lol that's how I am also.
FastPete is offline
Old 01-23-2014, 02:01 PM
  #245
DanielC.'s Avatar
Trader Rating: 56 (100%+)
Lol. I'll post some pics as I go. Desoto is officially out of stock
DanielC. is offline
Old 01-23-2014, 02:06 PM
  #246
Trader Rating: 19 (100%+)
That's a pretty beefy looking sway bar for a 1/10 buggy....
Jonny5 is offline
Old 01-23-2014, 02:08 PM
  #247
Captcha's Avatar
That's what she said......
Captcha is offline
Old 01-23-2014, 02:16 PM
  #248
elex300's Avatar
Trader Rating: 106 (100%+)
What other option parts are you putting on it right out of the gate?
elex300 is offline
Old 01-23-2014, 03:17 PM
  #249
DanielC.'s Avatar
Just the carbide diff balls. My RM has the aluminum front pivot, so I have a spare plastic one if I manage to break one.
Build notes (will update as I progress through the build):
Steering assembly includes steel washers now instead of the flimsy aluminum ones
Savox 1257/1258 servo only needs a single thin shim to line up properly
Ball cups look like a different material
Ream out the rear arms. They are tight!!
Manual shows the wrong RF hinge pin holder on the zoomed view. Go by the exploded view on step 16 and the stock setup sheet. Should be 1 down front, 2 down rear
Diff spring looks updated. No binding!
Transmission binds until you crank down all the screws. Looks like the mold has very tight tolerances. Spins free after all the screws are snug
Black gear cover! Need one of these for the RM too.
RM Body will not line up fully with the MM chassis, slightly different angle at rear of chassis.
DanielC. is offline
Old 01-23-2014, 04:23 PM
  #250
vr6cj's Avatar
Trader Rating: 124 (100%+)
Yeah, dang forgot to order the carbides, 70t spur and gold shock shafts when I ordered. Guess ill do that.
to bad kit doesnt include these items
still excited to get
vr6cj is offline
Old 01-23-2014, 04:24 PM
  #251
BOLISARIO's Avatar
Thanks for providing us build updates.
Just bought a Savox 1257, now I know what shims to use.
Old 01-23-2014, 05:15 PM
  #252
You can use the AE 1/8th carbide diff balls or better yet, order a bfast kit.
shagino is offline
Old 01-23-2014, 06:35 PM
  #253
wrightcs77's Avatar
Trader Rating: 549 (100%+)
I'm jelly too.
Been swamped with life....lol.
Send me PM's with build tips, mods, option parts and I will update the first post.
wrightcs77 is offline
Old 01-23-2014, 07:10 PM
  #254
elex300's Avatar
I had binding in the tranny on my RM buggy. I had to sand out some of the inside of the male half of the case and it spins free now. Probably the same for this buggy too.
elex300 is offline
Old 01-23-2014, 07:29 PM
  #255
RCmayor's Avatar
Ya on the rear motor it doesn't really bind, just don't tighten the bolts all the way. Just use threadlock on the motor plate holes and stop tightening right when the screws bottom.
RCmayor is offline
