Serpent Spyder SRX-2 Mid Motor Buggy Thread
#2206
Hope someone confirms this soon so I can place the order asap. Trying to get these here by Saturday for races.
#2208
Anyone know when the new version MM will be out?
#2211
Can someone tell me what diff fluid and shock fluids to use on clay tracks? The car is on it's way but I am going to the hobby ship now so wanted to pick some up. Only a couple small/medium jumps, medium bite. Thank you !! Whatever weights that will help with traction. I always seem to have traction problems no matter what track I run on. I am still fairly new to racing so a lot of it is most likely driver error and throttle usage
#2212
For the shocks, try 32.5F/30R. I use PT Racing Oils so I'm really using CST now instead of weight.
#2213
Is 500192 the correct gear diff? How does the ball diff do compared to th gear diff? Wouldn't the gear diff get me better traction? Or no? Never used a ball diff before so I have no idea how well they work.
#2215
I am running on clay right now but in summer it's just regular loose dirt. Would the gear diff be ok on clay? How much u want for your extra one?
#2218
I'm hoping someone can help me out. I'm having trouble with the ball diff on my mm. I've built the diff several times, and am having trouble with the diff loosening up on me each time. Once I get it assembled, I start to follow the diff break in procedure that's pinned on the first page of the forum, and every time my diff nut loosens and will not hold. I'm obviously doing something wrong, but not sure as I'm following the steps in the kit when assembling the ball diff and transmission. The only thing I can think of is how I have the diff oriented in the transmission. The manual says to orient the adjustment screw to the right hand side. I'm taking this to mean that the diff adjustment screw would be opposite the main spur and pinion gear. Any thoughts?
Thanks for your time,
Matt
Matt
#2220
Is this just during the diff break in procedure or are you running the kit on the track and it starts slipping? I find that I always need to make the diff a lot tighter than I think. When I do the allen in the outdrives and attempt to turn the diff gear, it doesn't move but I still need to go tighter to not slip on the track.
It doesn't matter which side the adjustment screw is on. I put it on the opposite side of the spur simply for convenience.
