Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 10-04-2015, 07:02 AM
  #2176
Originally Posted by dynastorm View Post
i checked on the exoteck website and dont see the aluminium diff nut listed under the srx2?
also my oem diff nut is also slipping in the plastic on a brand new diff kit. at this point I cant tighten it and I now cant even get the nut out. it just spins and i cant loosen it. any ideas on how to remove it with damaging the rest of the new parts?
ok well I finally got the diff screw and nut out. now im going back together, when I tighten the diff do I tighten the screw so that the plastic diff nut bottoms out in the cup so that there is no space between the ears of the plastic nut holder and the slits in the cup?
dynastorm is offline
Old 10-04-2015, 07:55 AM
  #2177
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
The exotek nut for the RB6 works, use some blue thread lock on it. I had to take a dremel with a new cut-off wheel and slot it and then use a screwdriver to get it out. This happened to me on a brand new build as well.
GrandeGixxer is offline
Old 10-04-2015, 08:09 AM
  #2178
ok Ill give that a shot, I have emailed both serpent and desoto racing to see if either of them can help me out as far as a replacement as this was a brand new complete diff.
Old 10-04-2015, 06:10 PM
  #2179
Trader Rating: 57 (100%+)
I'm confused at what you mean here. In the first post, you say that the diff nut is spinning in the plastic? I've never heard of that issue but I'll give you benefit of the doubt. Then in the second post, you say that you can tighten the diff. If the nut was stripped in the plastic and spinning, there's no way you'd be able to tighten it.
Not quite sure what the problem here is...
shagino is offline
Old 10-04-2015, 06:33 PM
  #2180
sorry for the confusion. the diff nut spinning in the plastic holder is a known issue from the past but I guess it was never fixed (luck of the draw i guess). I ended up using a dremel to cut a slit through the plastic into the metal nut and i was able to get it out. I ended up using an old diff nut that I had so I could now tighten up the diff.
Old 10-04-2015, 06:53 PM
  #2181
Ah, gotcha. I follow this thread and the FB pretty regularly and I've never heard of this issue. It must have been cranked down really tight to get it spinning like that.
shagino is offline
Old 10-04-2015, 07:11 PM
  #2182
to be honest I was only able to get like 4-5 turns on it before it started spinning. so that was the reason for my other question. how far should the plastic nut come to bottoming out on the slits in the hub? if I look into the hub i can see that the screw threads are just about poking out of the plastic. pretty much flush. is that too tight?
Old 10-05-2015, 01:47 AM
  #2183
The screw should come out of the nut about 1mm or a little less. I would tighten the screw fully until it bottoms out but not over tighten it.
rxmeador is offline
Old 10-05-2015, 04:08 AM
  #2184
I just built my car a couple of months ago and had the same issue. If you go a couple pages back others recommended the RB6 nut.
Old 10-05-2015, 02:28 PM
  #2185
Wow! That's crazy guys. I'd contact Serpent for sure but I don't think it's a widespread issue.
shagino is offline
Old 10-08-2015, 04:56 AM
  #2186
Trader Rating: 17 (100%+)
I'm having a brain fart moment here. On the rear hinge pin holders with the inserts, when they 2 down does that mean the number is down or the hole is down. Thanks guys
bkuff-losi is offline
Old 10-08-2015, 07:30 AM
  #2187
Hole down. There's an arrow right above the hole but it's harder to see. I just go by the hole instead but the arrow points down too.
shagino is offline
Old 10-08-2015, 07:49 AM
  #2188
Thank you for response here and on fb
Old 10-08-2015, 05:17 PM
  #2189
i searched and cant find the answer. is it possible to buy just the sock rod ends other than buying the complete $20 set? I see they have hem listed but I think they are for the sct and not the srx2 as they are listed as "long"
http://www.amainhobbies.com/rc-cars-...yU0aAh0J8P8HAQ
Old 10-09-2015, 07:13 PM
  #2190
goehm's Avatar
Trader Rating: 45 (100%+)
I'm not sure. I ended up buying the rod ends and cups for the B5M and have been using them. The cups have varying height, and while the two lowest height cups don't fit at all it's still a good value for the remainder.
You can get the ends w/ pivot balls for under $6, and cups for for under $6 as well.
Note the AE cups are a pretty tight fit on the SRX2 ends because of the SRX2 key/notch that prevents the cup from spinning. In other words, the slot on the AE cup is small enough for the shock shaft to fit through, but not quite enough for the SRX2 notch - if that makes any sense. However, I don't see a reason that the SRX2 cups wouldn't fit on an AE end.
http://www.amainhobbies.com/rc-cars-...c91448/p275222
http://www.amainhobbies.com/rc-cars-...c91310/p239779
goehm is offline
