Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 03-19-2015, 12:15 PM
  #2011
itsjusme's Avatar
Originally Posted by DIRT DIGGER View Post
Looking for forward bite. Gona try a few more things and if not it's going for sale gona try a Losi. If anyone's looking to buy one let me know it's like new ran few times. Thanks
Rear hubs forward.
.05 toe in on rear hubs.
itsjusme is offline
Old 03-19-2015, 12:18 PM
  #2012
Originally Posted by itsjusme View Post
Rear hubs forward.
I have that now I'm running fast stock setup with a 10.5
DIRT DIGGER is offline
Old 03-19-2015, 12:38 PM
  #2013
itsjusme's Avatar
Go to rear brass block with 0 up in front 2 down in back.
That setup is for a stock motor
itsjusme is offline
Old 03-19-2015, 12:49 PM
  #2014
thanks i sent u a pm
Old 03-19-2015, 01:48 PM
  #2015
goehm's Avatar
Trader Rating: 45 (100%+)
In addition to adding weight (which you don't always want to do in stock), you can also adjust/reduce anti-squat, make the rear end softer, or remove some shock limiters from your front shocks for more weight transfer to the rear under acceleration.
goehm is offline
Old 03-19-2015, 02:08 PM
  #2016
im running mod
Old 03-19-2015, 03:43 PM
  #2017
Trader Rating: 57 (100%+)
im running mod
I think the 10.5 gave that away. goehm was saying stock because of the setup you are using.
Have you tried letting someone else at the track drive your car? Because of the questions that you keep asking, I really think it's driving style as opposed to setup. I'm not sure switching to Losi will solve your problems. Good luck whichever way that you end up going.
shagino is offline
Old 03-19-2015, 03:52 PM
  #2018
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
He sold his B5M to get this car because traction was not right. And the losi will be MUCH worse.
Wildcat1971 is offline
Old 03-19-2015, 04:40 PM
  #2019
tony montana's Avatar
Trader Rating: 76 (100%+)
Totally agree the losi will be way more loose.
tony montana is offline
Old 03-19-2015, 10:02 PM
  #2020
hacker's Avatar
Trader Rating: 141 (100%+)
thats funny right there
hacker is offline
Old 03-20-2015, 04:13 AM
  #2021
Old 03-20-2015, 05:24 AM
  #2022
Dirt Digger,
You seem to be convinced that the buggy or the setup is holding you back. You mentioned in a PM that you have a race tonight. Find your fastest race tonight and look at your fast lap, top 5/10/20. Compare that against the best run tonight.
If you are off by more than 1 second in either fast lap or top 5, no setup change or brand is going to make that up for you.
Here's something that Billy Easton said on the FB page a while back that I think may help you:
I played this game the other day..Forza 4..... The game is obviously built around, what is and is not possible by the fundamentals and laws of inertia,gravity,traction and so on.. Anyway, the car i was playing never seemed to turn, and, until i approached the turns at the proper speed, there was no way this car was turning.. I guess, what im trying to say in general, and not necessarily directed towards you. A racing car has its limits no matter what we expect it should do.. You have to drive within the limits of the car in order to turn fast laps.. Just like the game, blowing turns and missing apex's translate slower lap times, against, braking the car,decelerating at the correct time, hitting the apex and throttling the car off the turn..RC cars are alot the same, you simply need to learn the limits of your car, and then drive within those boundaries.
shagino is offline
Old 03-20-2015, 05:38 AM
  #2023
Thumbs up
Dirt Digger,
Well said thank you sir for the great advice. Not like others with there dumb ass comments.
Old 03-20-2015, 05:50 AM
  #2024
99windy's Avatar
Questions?? Mt Set up for Low Bite Tracks
Gents,
My current set up for low bite tracks, needs a bit more on power steering, so when you viewed my set up can you please advise.
Front.
0 deg caster.
std front bulkhead.
stock caster block.
Spindle shims all up.
Camber link on middle hole inboard no shims and outer hole outboard
Opt 3 Ackerman arm. 1mm bump steer
Shocks
2x 1.7mm pistons
35wt Ae oil
Blue Springs
Rest as per kit.
Wishbones outer and number 2 on tower.
Rear.
Stock rear upright. 0.5 out board toe in. Hole C(Outer hole), spaced to rear.
Camber link in point 1(longest arm possible) no shims.
Pills FR number 2 up and wide, RR number 1 down wide.
Rear roll bar fitted 1.5mm
Shocks
2 x 1.6mm pistons
27.5 wt AE oil
Astro Orange
Rest as per kit.
Wishbones outer and number 3 on tower.
Wing mount Stock.
1.5 degree camber front and rear
Ride height 19mm front, 20mm rear
Ballast,
50 grams under shorty, all the way forward.
50 grams under receiver and ESC
20 grams on top of servo.
Diff height med.
Any help you can give is appreciated.
99windy is offline
Old 03-20-2015, 06:02 AM
  #2025
No problem. Keep in mind that everyone is willing to help. We only know what you tell us and you continue to ask for setup changes on how to gain one thing without saying how the buggy is performing in other areas of the track.It was frustrating seeing you ask for the same thing and expect different results. There's no magic bullet here.
That's why letting a fast driver drive my buggy was so helpful to me. It showed me that it wasn't the setup. It was my driving style. That left me with, change my driving style or change the setup to suit my driving style.
shagino is offline
