Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1996
hey guys just curious which battery type would give the car best traction? shorty, saddle or brick pack? thanks
#1997
#1998
I did a quick measurement of some:
Serpent 18.8mm
Xray 24.4
AE pin or sch pin 23.2
DE i think 22-4 23.7
DE RB6 18.1
So I think the RB6 are the closest. Im not really sure Id want to shim them out tho, our hex is pretty thin already
Maybe a shim on the inside against the bearing if you can get somethin in there
Serpent 18.8mm
Xray 24.4
DE RB6 18.1
#2000
Serpent 18.8mm
Xray 24.4
DE RB6 18.1
Serpent 18.8mm
Xray 24.4
DE RB6 18.1
Don't think it's that simple as there's so many unknowns here. Saddle and brick should behave the same and is heavier than a shorty. Shifting the shorty around helps also.
#2001
Is the offset right with the other wheels or only the serpent? Just to get the car on the track I used some B4 Avid wheels and tires I had. Ground down the front hex, but the car looked funny. rear track looked narrow or the front was too wide. I also don't want to buy many sets with everything going on, 2.4 etc.
#2003
Lipo
Guys,
I use a shorty in mine with a brass ballast weight underneath. I could use a saddle pack, but moving the shorty around helps me gain or lose sterring as required. Is a brill tuning tool.
Have been trying a few things on mine in teh uk on a low grip set up, just about there for me, needs some on power steering but otherwise happy with the handling so far. Will post my set up later as i just cannot remember it all.
Cheers
Lee
Cheers
Lee
#2004
We are finding that the shorty middle to full back is the working range for most all the tracks we are seeing in the US. I always test a brick pack on each new track I see and 95% of the time I use a shorty.
#2005
on SMOOTH high bite tracks adjusting the shorty around is all a give n take but a nice tuning feature to get the setup dialed in.
#2006
What's the best thing I can change on this buggy to get a little more bite? I'm trying to get more out of it.
#2007
#2008
#2009
#2010
