Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 02-22-2015, 01:11 PM
  #1921
LowBoost's Avatar
Trader Rating: 63 (100%+)
Originally Posted by shagino View Post
Pic detail isn't sharp enough but I'm pretty sure you have the rear hubs on backwards. The cutout on the hub is supposed to face forwards for the MM kit. Make sure you take the inserts out of the hub before swapping.
I'll take another picture without the wheel and post it.
LowBoost is offline
Old 02-22-2015, 01:32 PM
  #1922
LowBoost's Avatar
Here it is:
LowBoost is offline
Old 02-22-2015, 01:51 PM
  #1923
Trader Rating: 57 (100%+)
Yeah, your hubs are backwards. Excuse the dirtiness of my buggy. Ran yesterday.
shagino is offline
Old 02-22-2015, 04:09 PM
  #1924
Originally Posted by LowBoost View Post
Here it is:
Yep they are on backwards. Don't pay attention to the R and L cast into the rear carriers, that only applies to the RM.
Tijuana_Taxi is offline
Old 02-22-2015, 04:15 PM
  #1925
i think mine are backwards too. so does the left go on the right side?
DIRT DIGGER is offline
Old 02-22-2015, 04:21 PM
  #1926
Trader Rating: 520 (100%+)
Yeah, just make sure you still keep the inserts going the correct direction..
flame56mx is offline
Old 02-22-2015, 04:49 PM
  #1927
Not all rear hubs have the lettering. The lettering is for the RM buggy. It's switched for the MM
shagino is offline
Old 02-22-2015, 04:53 PM
  #1928
Thank you very much. Anyone have any idea what pinion i should start with a 10.5 motor in this buggy?
Old 02-23-2015, 06:03 AM
  #1929
22-23 with the stock spur
Old 02-24-2015, 05:47 AM
  #1930
King DORK's Avatar
Trader Rating: 51 (100%+)
Has anyone tried either the RCShox or CSI pistons with this car? I have a set of RCShox two stage pistons that I'm gonna try in this buggy next rebuild. I tried CSI blues in my B4.2 when I had it and really liked them, just didn't like the car
King DORK is offline
Old 02-28-2015, 05:26 PM
  #1931
anyone know where to find that fast stock setup? i dont have facebook and cant find it anywhere. wondering if its better than box setup?
Old 02-28-2015, 05:30 PM
  #1932
slakr's Avatar
Trader Rating: 36 (100%+)
Replied to your PM... send me back your e-mail & I'll get it to you.
slakr is offline
Old 02-28-2015, 06:45 PM
  #1933
snuvet75's Avatar
Trader Rating: 16 (94%+)
Hi guys. I'm thinking of getting back to offroad and Spyder seems to be a great car. I have some questions:
1. What tires would you use for indoor, medium size, slick, med-high traction track?
2. I see some option weights I can put in the car. Do you guys use it a lot? The part "Serpent SRX2 MM Ballast Weight"- where in the car is this used? Rear? Front? Can't find the reference. What about brass pivot holder?
3. Do you have to use roll bars a lot? The kit obviously doesn't come with it.
4. What is the benefit of using "Steering arm brass" over plastic? I guess I'm asking about weight effect. I don't use any aluminum parts on arms for obvious reason. Would you say the same?
5. What is the good starting FDR for the above track for 17.5T and 13.5T?
6. Do you feel the need of changing kickup a lot from the kit setup?
7. I heard the shock orings are very prone to leaking. Would you recommend to get different orings? Onroad black orings have the same issue.
Sorry about lots of questions. I'd appreciate your help.
snuvet75 is offline
Old 02-28-2015, 07:08 PM
  #1934
tony montana's Avatar
Trader Rating: 76 (100%+)
You really do not need any options. That's the great thing about this car. A good safe tire would be a m4 electron or dirt webs.
tony montana is offline
Old 02-28-2015, 07:13 PM
  #1935
1. How is it slick and med/high traction?
2. I used the balance weight when I needed more traction. It goes in front of the motor on the chassis. Screws in with 2 M3x8 BH screws I think.
3. Probably not on those conditions. I do use roll bars on a super high-traction carpet track though.
4. Brass steering arms give more steering over the plastic. I haven't personally used them. I use the aluminum bulkhead.
5. I'm running about 5.3-5.4 for 17.5 on a small indoor track. Novak says 7.0 for 13.5 so probably 6.5
6. Some setups are using different kickups but in order to change it, you either need the aluminum or brass front bulkhead AND the proper hinge pin holder.
7. That's true. They might be okay now but I'd replace them with the Traxxas X-rings out of the box. Cheaper than Kyosho. Read the FAQ's for some build tips and tools needed.
Sign up for the FB group if you're on FB. It's 1000x better than the forum for this buggy.
Here's a FAQ that I posted on FB:
http://www.petitrc.com/setup/serpent...srx2/SRX2_FAQ/
A lot of the quotes by Billy were actually made on the FB page. That's the kind of info that we get there and not here.
shagino is offline
