Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 02-05-2015, 07:59 PM
  #1801
Mxer59's Avatar
Trader Rating: 114 (100%+)
What bodies fit these cars? Is it pretty much stock and JCONCEPTS right now?
Mxer59 is offline
Old 02-05-2015, 09:17 PM
  #1802
Yes... I think the stock body is a pretty snazzy body though. Not sure why people want so many options. OK, well I do but that's what paint is for.
Barge is offline
Old 02-06-2015, 07:32 AM
  #1803
The JC body has more downforce on higher speed tracks.
Stealth_RT is offline
Old 02-06-2015, 03:46 PM
  #1804
anyone know what spacers are used behind a savok servo?
DIRT DIGGER is offline
Old 02-06-2015, 03:52 PM
  #1805
http://www.serpent.com/product/500376/
Ordered! Can't wait to try em.
Old 02-06-2015, 05:13 PM
  #1806
can someone please help trying to get my build done need to know what spacers to use for savok servo? please
Old 02-06-2015, 05:24 PM
  #1807
I used 1, 2mm spacer
Woodbutcher is offline
Old 02-06-2015, 05:34 PM
  #1808
ok thanks u use both of them?
Old 02-06-2015, 07:26 PM
  #1809
anyone know which inserts go in the transmission case for billys spectrum setup?
Old 02-06-2015, 07:27 PM
  #1810
tony montana's Avatar
Trader Rating: 76 (100%+)
Run the diff in the middle position
tony montana is offline
Old 02-07-2015, 01:40 PM
  #1811
LowBoost's Avatar
Trader Rating: 63 (100%+)
Just received my Spyder SRX-2 MM. Started the build. Based on what I read before, I purchased some nut drivers tool kit. (4, 5, 5.5, 7mm)
Looks like the 4 is too small and the 5 is too large for steps 11 and 12.
I am stuck here without proper tools. Are these the proper tools?
Looks like I would need a 4.5mm instead? Can anyone tell me which tools I need?
LowBoost is offline
Old 02-07-2015, 02:46 PM
  #1812
4.5mm is the correct size needed. A 3/16" will work to get you by.
Barge is offline
Old 02-07-2015, 03:28 PM
  #1813
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Just redid setup, still missing the black front springs and alum front bulkhead, can't wait to see how it drives.
JEFFs SC10 is offline
Old 02-07-2015, 03:57 PM
  #1814
Trader Rating: 57 (100%+)
You need the 4 and the 4.5. 4.5 for the steps mentioned but you'll need the 4 for the shock shafts. For 4mm and 5mm, a simple cross wrench is good enough.
1.5/2.0/2.5mm Hex wrenches
4/4.5/5/5.5/7mm Hex nut drivers
3mm turnbuckle wrench
shagino is offline
Old 02-07-2015, 05:02 PM
  #1815
did u run it yet want to know how it is?? what shock oils u running?
