Serpent Spyder SRX-2 Mid Motor Buggy Thread >
Like Tree2Likes
Old 11-25-2014, 11:03 AM
  #1666
Suspended
Trader Rating: 6 (88%+)
Originally Posted by elex300 View Post
I personally run the full brace. I do however only use 2 of the 4 battery hold down points. I use the 2 in the front with a Jconcepts B5M battery brace.
youre welcome!
JaderL is offline
Old 11-25-2014, 04:05 PM
  #1667
tony montana's Avatar
Trader Rating: 76 (100%+)
Originally Posted by jkirkwood View Post
It does seem to increase traction to a point. In modified I feel the additional flex makes the car inconsistent.
I agree with you as well. I have run the full brace and then a brace with only the center leg. The car does weird inconsistent things with the one leg brace.
tony montana is offline
Old 11-25-2014, 05:25 PM
  #1668
MantisWorx's Avatar
Trader Rating: 28 (97%+)
I run the single turnbuckle style and the car is much more consistent but I am not running on grip levels as high as you guys are. I can see how it would act wierd with high grip. This past saturday I had my best night out with the car and came sooooooo close to 15 laps which is unheard of on this track and really i had it but bobbled on the last jump of the last lap
I had more fun and felt more comfortable driving this car than my wheeler!
Attached Thumbnails Serpent Spyder SRX-2 Mid Motor Buggy Thread-01c34f13d443c775c857b785813fa0efa3f9650670.jpg
MantisWorx is offline
Old 11-27-2014, 07:00 AM
  #1669
Trader Rating: 17 (100%+)
can someone help me out ? this question is for the rm buggy,,i am asking in both threads so i can get a faster reply.... im running the stock spur gear 78t with a hobbywing just stock 17.5 combo.. what pinion should i run or is there another gearing set up i should run ? thanks
bkuff-losi is offline
Old 11-27-2014, 04:46 PM
  #1670
Trader Rating: 23 (100%+)
what servo is recommended?i see a few people had issues with certain brands.
chad423 is offline
Old 11-27-2014, 05:44 PM
  #1671
MantisWorx's Avatar
78 is going to be too big for 17.5, go with the 72t and 33 to start off with
Old 11-27-2014, 10:17 PM
  #1672
King DORK's Avatar
Trader Rating: 51 (100%+)
I run a Xpert 3431 low profile in mine and love it. Very fast and smooth at 6.0v and about $70.
King DORK is offline
Old 11-28-2014, 11:13 AM
  #1673
elex300's Avatar
Trader Rating: 106 (100%+)
I run Savox 1257.
elex300 is offline
Old 11-28-2014, 12:14 PM
  #1674
thks for the replies.do you need to ream the a-arms.if so what size reamer do you need.
chad423 is offline
Old 12-02-2014, 03:07 PM
  #1675
i have never reamed out a arm on one of these cars, on my car the rear inner pins do seem to corrode and/or get dirt around them and get tight.
The manual shows the sizes of all the pins but the rear inner pins ......
ooberman is offline
Old 12-10-2014, 11:47 AM
  #1676
Just got my MM and got the electronics in and started my indoor carpet setup based on this one: http://www.petitrc.com/setup/serpent...s_MIO20141109/
I have it all setup the same but I have my rear shock towers bottomed out and can only get down to 22mm ride height. Why is that? Only difference is I put blue springs in the rear instead of green (because that's all I had) but will that make a 5mm difference? Are the green springs shorter? I'm going to stop and pick up some grey AE springs that were mentioned earlier in this thread for carpet but I'm not sure that will lower it down to the 17mm this calls for.
Also, does anyone have a link to a good stock 17.5 blinky MM carpet setup sheet? I cannot seem to find one. Thanks!
louie8269 is offline
Old 12-10-2014, 11:52 AM
  #1677
wrightcs77's Avatar
Trader Rating: 549 (100%+)
Serpent makes shorter rear springs specifically for carpet running.
wrightcs77 is offline
Old 12-10-2014, 07:31 PM
  #1678
psycho02's Avatar
Where is THE best place to get serpent parts?
psycho02 is offline
Old 12-10-2014, 10:24 PM
  #1679
onekiwi's Avatar
I use AE springs and they can get me to lowest about 16mm.
Atm I have blue rear grey front
[email protected] 37+32tlr
Tight track with slicks and addative
onekiwi is offline
Old 12-11-2014, 02:42 AM
  #1680
I went to my LHS yesterday after my previous post and looked at the AE springs. The diameter looks too small and the length looks the same as the regular serpent springs? Do you have a part# for the AE or TLR springs you're using? I'm going to order the serpent springs soon but I have a race tomorrow night and I would like to get my rear end lower if possible.
TIA
